Spare tire Christmas light setup tips?
Shadowsquatch
GA
Cactus Grey 2-Door Wildtrak
This will be my Bronco’s first Christmas (bought on Halloween) and I want to decorate my spare tire to celebrate. I’m thinking about a garland with lights, a bow and some decorations. It’ll be fun to surprise the kids.
Any kits you’d recommend?
What’s the best way to wire this up?
Anything I should watch out for?
Mine is a 2-door Wildtrak if that matters.
TIA!
helifino16
Ron
Mount Sinai, NY (Long Island)
There's a power outlet near the light in the Passenger rear panel. You could connect something there and run the wire under the window to the spare tire location. That's probably the easiest way, but you would have to remember to unplug it - it stays on for about 20-30 minutes after shutdown.
Be careful - some places have pretty strict laws about lights in a vehicle. I know where we live - someone new does this every year with rainbow lights, and every year they get a ticket because lights can only be white or yellow (unless they are for stopping/taiights)
That said - easiest way would be the 12V power point in the rear cargo area, just close the glass/softtop on the wire.
Shadowsquatch
Shadowsquatch
GA
Thanks and appreciate the callout on the allowable colors. It's white or yellow for me too. I also got a spare tire brake light so I'll have a splash of red too. I can tap on the brakes frequently to simulate flashing :)
FleshTuxedo
A
PA
'22 OBX 2dr.
Mine turns off immediately.
Go to Michaels. They have pre-lit ones that are the perfect size for the spare, and theyre cheap.
BDLNDZ
Pete
2024 Bronco
We used to decorate our motorcycles for a holiday parade and we just used battery-operated lights. Easy install & removal.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
TIA!
This sounds cool and festive! We'd love to see pictures of your Bronco. We hope you and your kids are enjoying your ride!
AZ_Craig
Craig
Mesa, AZ
2024 Ford Bronco Raptor, 2023 Kia EV6 GT
Why am I not surprised when I read that you lived in California?
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Why is no one suggesting using the trailer wiring socket. Turns on and off with the running lights.
HeliPilot
Kenny
CT
2022 2.7L SAS
There will be some that flash with blinkers, others will come on only with brakes, and the rest will work as normal. EDIT: a handful won’t work at all!! Love it!!
Dreamer
Kevin
Connecticut
Ford Mustang GT convertible
I purchased some regular LED Christmas lights that plug into a standard house outlet. I plan on using the power outlet on the backside of the center console. When I tested it, mine turns on when the vehicle is started and turns off when the vehicle is shut off. Just plan on running a small extension cord to the back of the vehicle.
I’ll just run the wire for the lights between the window and the tailgate.
