SOLD
FreddieLee
Freddie
Bronco & Tesla M3
Is there a plug and play harness for the D-5.1300?
Les Korcala
Les
Florence, Montana
Xterra
Are u using factory speaker wires ? With such of nice amp I would stock wires are junk , thin connectors very easy to loos lot of great quality sound. I ran all new 12-14 G speaker wires I had to take floor trauma anyways for running Power wire and speed wire to the harness. Still in progress
i have similar amp but non DSP. LC 6 . 1200 and need to tap in +12 v remote wire to fuse panel , for some reason GTO on my amp is not sensing speaker inputs. Perhaps is not capable with new Broncos.
so what I did is got simple harness plugs in to speaker outs and just soldered speed wire and ran to the main amp.
still in process.
DJ1
Minnesota
2022 Honda Civic Si, 2020 Toyota Tundra TRD Pro
You can get either a loop back harness or T harness from multiple places. Yes, PNP can do both. Nothing magical about connecting to the D-5.1300, the harness will just be wires in to the speaker level inputs and wires out to go back to the factory speaker wire (if you go with a loop back).
https://www.bronco6g.com/forum/thre...-dsp-speakers-and-sub-lots-of-pictures.43856/
Like @Les Korcala said (I think), you can run your own speaker wire pretty easily as long as you are taking panels out and replacing speakers.
DJ1
Minnesota
still in process.
Les - check with Audio Control about your GTO. You probably need this to trick your head unit into sending a signal without the factory speakers:
https://www.audiocontrol.com/car-audio/accessories/ac-lgd-20/
Then GTO will work.
Or use a remote wire, which is easy to add if you are already in there installing other stuff.
