Soft Top Trunk Access Improvement
BadMansquatch
TN
Hello!
I was just wondering if anyone knows of any aftermarket solutions that make trunk access better for the soft top. It seems it would be hard to get large items in the back with the limited access due to only being able to pivot the rear window up a few degrees.
Karl_in_Chicago
Karl
Chicago
You probably aren't going to like this but there just aren't a whole lot of options. It's either scrunch under the lifted rear window, load from the front (which brings its own obvious limitations) or remove the rear window for maximum access. Of course some die-hard is probably going to shout out "It's not a problem if you don't have the top on in the first place!" ;)
BadMansquatch
TN
Hahaha, I’m waiting for it 😂.
dan79
dan
ma
08 f250
id love to hear some options myself being 6 3 i have a hard time seeing in there even when its lifted up
Bschurr
NY
Like my Wranglers, if you want to put junk in the trunk you need to roll up/remove the rear window
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
Compared to a Jeep soft top, (not knocking just have experience) the tilt up feature on the Bronco is a nice touch. Access id limited other than taking the window off, if you are comparing to hard top... its not close to loading easily.
Bschurr
NY
Agreed but, I would give up the tilt up soft top in a heartbeat to eliminate the wavy rear bacon-like windows!
Headsong
You can tighten them up to eliminate the wavy.
Bschurr
NY
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
You can eliminate it but you lose the ability to lift. Just put some bows on both sides of window.
Headsong
Nah, the guy in that one vid using the butt connectors? eliminated it and didn't affect the lift at all.
OregonMike
Gresham, OR
2010 Fusion, 2021 Bronco
Yeah, agree. We had a soft top Wrangler 20-odd years ago, and I like the rear lift on the Bronco soft top better.
cricex
Charles
Austin, Texas
2.7L CG Badlands Sasquatch
You can just pull the rear window off in a couple of minutes
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
