Soft Top Tension Cable Issue
beetle
SoCal
2022 Bronco
My tension cables have come out of the screw mounts.
Where can i buy replacement tension cables for the trektop soft top ?
Both came right out of the mounts.
I can’t find replacements anywhere.
Did you ever find those replacement mounts? My cable came out too.
beetle
SoCal
2022 Bronco
Soft Top Tension Cable – Front
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. NOTE: Left hand (LH) shown, right hand (RH) similar.
    Release the front cable from the front retainer.
    Drill the rivet and release the rear end of the cable.
    Pull the cable backwards from the canopy and remove.
Installation
    Feed the cable from rear end of the canopy.
  1. To install, reverse the removal procedure.
Do you happen to know the cable PN? Closest I can find is M2DZ7852806A or B
beetle
SoCal
2022 Bronco
M2DZ-78514B28-B
Thanks for getting back to me, that's not the cable that broke on mine tho. I think mine is 806B. Ford wants to replace the whole soft top and take a couple months on my dime to do so. Nope!
beetle
SoCal
2022 Bronco
M2DZ-78514B28-B
Actually ended up buying your recommended part. the 806B is on backorder. Praying I can follow your steps and fix my soft top!
beetle
SoCal
2022 Bronco
Shows 18 in Detroit warehouse?????
Is that the 806B? I'm starting to think this is a faulty part in the build. Should be recalled tbh. The service guy let slip that taking the top down and up wears the cable down. Its only 2 years old, cable should go 10k opens and closes at least.
flip
Phil
IN
www.ruxerparts.com
Fords
Yes, the diagram uses partial base numbers for part callout.
beetle
SoCal
2022 Bronco
Well I have the part, but I think I might be able to repair it. The bead at the spring end broke in half. Def faulty, but I can probably fix it. Thanks for the help, I'll be reporting this to NHTSA.
flip
Phil
IN
www.ruxerparts.com
Fords
Be careful putting it on or taking off, first one we did the tech got his hand opened up. No stitches but it was deep and the cable doesn't have any type of protective coating. Wear gloves.
beetle
SoCal
2022 Bronco
Thanks for the heads up. If I can manage the repair I think it would be a bit safer.
