Soft top questions
OneNut3377
Trey
FL
2022 Bronco
Good afternoon,
I recently purchased my 2021 OB and have a couple of questions about the soft top. I have searched the forums and have not found to much, so I apologize if some of this has been asked before.
Is there a special method for raising and lowering the soft top all the way up and down without scratching the roll cage? I tried it once by myself and now have a chunk taken out of the paint.
Next is about maintenance of the soft top. Can I use ordinary window cleaner on the plastic windows and do people use automatic car washes?
pillar406
Javier
www.keeseemotorcompany.com
2024 Bronco
Good afternoon,
I've seen a few people that have had this issue. There is a correct way its just a slow and methodical process. I saw a customer vehicle about 3 weeks ago that had some protection for the roll bars because of this issue. Check out this stuff I found. https://buckleupoffroad.com/product...otection-for-2021-ford-bronco-4-door-d-pillar
They are currently sold out but I'm pretty sure you could find other stuff just like this
Arjineal
Pa
2008 Saturn Astra
I have the IAG EZ lift soft top assist and it actually makes it much easier to lower the top without contacting the roll bars. I wouldn't use window cleaner on mine but that doesn't mean you can't. Don't use the automatic car wash.
Area51BS
Ron
Badlands non SAS 4dr 2.3
There is a TSB where Ford applies a fix. My 22 hasn’t scratched yet. Will see if I have the TSB. I didn’t take it in as it appears fixed at factory.
OneNut3377
OneNut3377
Trey
FL
2022 Bronco
Great information, exactly what I was looking for!
Thank you everyone.
HoosierDaddy
__ Eric
NW. Indiana
Any plastic window is super (cala-)fragile.(isticexpealidocious)
The ONLY way my plastics get cleaned are MUCH water, a super soft, super soapy wash mitt, clean, quality microfiber towel to dry.
Yeah, you know you're singing it now. Lol
Sanndmann3
Don
Detroit
75 Bronco 23 Wildtrak
As long as we are talking softtops... would it be bad to drive on expressway with windows down? Would it cause the rear window to balloon at all?
Dmorty217
Derek
Venice FL
Camery
You can adjust the soft top but to prevent rubbing on the cage and scratching the paint you need 2 people or there are several company’s that make plastic protectors for this. I have the IAG versions but there are plenty more to choose from and all serve the same purpose. Also most of the time you won’t have a second person to help you, so just buy a protector.
88 FoxBody
Dustin
Northern VA
1988 fox body mustang w/ 347ci motor
What does it look like installed? I have never seen this before. My bronco is going in for a few other TSB’s and warranty work. I may throw this on their plate also.
Area51BS
Ron
I’ve noticed no issues
Area51BS
Ron
Will see if I can get a pic when the sun is up. Not sure how visible parts are with top closed.
Bschurr
NY
Use Plexus on the plastic windows - I have used it on my MGB, Jeeps & Bronco. It is truly amazing for keeping it clear and buffs out light scratches too!
https://a.co/d/1LtRcjt
