Soft Top Middle Latch Not engaging
rllw
rob
boulder
bronco
Hello,
Has anyone had an issue with the middle latch not engaging on their soft top? This is the latch above the drivers side rear door. I had the rear windows off last week, and now when I close the soft top, this middle latch will not engage.
Thanks!
rllw
Ford Bronco Soft Top Middle Latch Not engaging 1
Ford Bronco Soft Top Middle Latch Not engaging 2
VelocityBronco
E
I had to pull down with some force to get it to latch when I put my top back up. Do you have your back windows in while you are trying to latch this? I did not, but if you do it might take even more pressure to pull that latch down?
rllw
rllw
rob
boulder
bronco
Thanks, yes, back windows were installed. I pulled with all my weight, but, it looks to be a few cm back.
flip
Phil
IN
www.ruxerparts.com
Fords
Did you try latching with the rear hatch lifted? Some of these have been tight but if it wasn't before, you might have some tension in the top material. Try leaving the rear up, latching and see how tight the hatch is to get secured.
straycat
St. Louis, MO
2011 Toyota Camry, 2021 Ford Bronco
Last time I had this issue, I made sure the passenger side clicked first, then the drivers side latched without issue. I fought with it for a while, but I seem to remember thats what fixed it for me.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
That's a good idea; I never thought of trying that.
I have the same issue with mine. I end up having to "drop" it from a few inches up and it then latches. I don't put my rear/side windows in until the roof is pulled latched up front.
nbennett14
Nathan
Illinois
13 Fusion, 14 Fusion, 07 Expedition, 14 Grand Cherokee SRT
I had to get up above and push it down b/c I couldn't get enough pulling it and it worked.
Cartman3132
Hopedale MA
Hello,
Thanks!
rllw
That center latch is a bitch.....the spring popped off mine on the passenger side too so I have to manually make sure its open so I can close it.
rllw
rllw
rob
boulder
bronco
Im sorry, but, what do you mean by rear hatch lifted?
22BlackDiamondGreen
Shawn
Louisville, KY
2013 Ford 150 1955 Ford F100
I had this issue and I loosen the plate and adjusted it has not reoccurred….. I do have issues latching in the retracted position but I think that is caused by IAG lift shocks
deanosf
dean
bronco
Same problem for me. I was going to work on it this weekend.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello,
Thanks!
rllw
Hi there. This latch concern doesn’t sound like something we want you to experience with your Bronco. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end.
rllw
rllw
rob
boulder
bronco
Wow, thank you for the proactive reach out. I sent you a PM.
DenverBronc
Luke
Denver
I had the same issue on the passenger side of my vehicle after doing some off-roading this past weekend with the top in position 1. Drove back to Denver and noticed a lot more whistling on the highway, then realized the hook wasn't latched properly.
Here's another thread with further discussion on the topic: Thread 'Soft top latch issue.' https://www.bronco6g.com/forum/threads/soft-top-latch-issue.30901/
Snowdogyyz
23 Ford Bronco Wildtrak
Check on where the latch hits the part of the roll bar mount where the hook goes around the bar. My latch was hitting well short. It’s two easy bolts to loosen and adjust. Now it’s not too easy but not hard at all either. Slightly firm pressure latches it which is what I wanted.
