Soft Top Cross Bars
Xinnes88X
Rocklin, California
2016 Nissan Frontier Pro-4x
Hi all! I just bought this rack and cross bar system for my softop. Was fairly easy to install and so far I am not hearing any noise generated by the cross bars at freeway speeds. They can hold up to 300 lbs and they are pretty inexpensive in price. Just thought I would share in case anyone with a soft top is looking for such a set up.
Ford Bronco Soft Top Cross Bars 1736289692703-zu
thesocalexplorer
Joe
Southern California
Sweet, nice to see options for the soft tops. Are they pretty easy to remove if you want to pop the top back on a whim?
X-Rack
Nick
Bethpage, NY
2022 Ford Bronco
Xinnes88X
Xinnes88X
Rocklin, California
Yah, they are easy to take off. Four bolts on each crossbar using a ratchet and a 30 torx (sp) bit. I plan to keep them on until the spring and then will take them off and use them only if I go on trips in the spring/summer/fall.
jorgem31
Jorge
Tampa
Does this separate the soft-top seal? Not that it really even seals anything, just don't want even more noise from air leaking in.
Rebel Bronc
Rob
Central NY
'23 OBX, 2dr, V6, 4.27
I bought this rack, but I'm going to the dark side (2 door, v6). I'll put it up in the WTS sub-forum.
