Soft Top brackets needed
Daboots
Minnesota
GMC Sierra
4/18/2024: I was lucky enough to find a OEM new soft top last fall but didn't realize there was additional hardware needed other then the rear window latches. Now that spring is here I was looking to swap the hard top our and realized I need some additional parts. I'm looking to the group to see if anyone has the following they are willing to part with.
Any Help would be appreciated!
Ford Bronco Soft Top brackets needed 1713466523852-8d
Ford Bronco Soft Top brackets needed 1713466345825-kq
PDM
Peter
2023 Bronco
I'm having the same issue, I was able to order the receivers from my local dealer for $40 each and are supposed to be here in a couple of days, I ordered the quarter panel brackets but they are on back order and doesn't look like I will be receiving them for months. Where did you get the rear window latches from? the dealer could not find them .
Daboots
Daboots
Minnesota
GMC Sierra
I was able to get them from the person I bought the soft top from. I wish I would have known about the other parts at the time.
PDM
Peter
2023 Bronco
Same here, they ended up selling the Bronco before either one of us realized there were more parts needed.
jeng99
Jen
Minnesota
2022 Bronco -4 door
The rear latches - you can find an aftermarket at Mountains2metal.com.
Kach Vartan
Los Angeles
Sedan
Does anyone know what size (and how many) bolts are needed for the 2 receivers that attach to the roll bar?
Dral97
Ford Bronco, Wrangler YJ and 392, BMW 4 series
I wish this wasn't such a hassle to do.
I'm considering ordering a newer Bronco later this year so I can get the dual-top option from the get-go. It shouldn't be this difficult to get an OEM soft top after the fact.
jwidmer
I have the 2 brackets for the rear.
I have the rear quarter panel brackets.
Ford Bronco Soft Top brackets needed IMG_7582
Ford Bronco Soft Top brackets needed IMG_7583
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
RedTailHawk
2024 Ford Bronco Raptor
anyone able to cobble together the full list of latches, brackets, etc needed to install an OEM soft top take-off (that didn't come with all those parts)?
