Slide-Out Tailgate
Seppy
Amy
Ford Bronco
We ordered a Bronco Heritage and want to know if we should install the slide-out tailgate? Is it worth it or does it compromise the cargo space?
Hoops
Savannah
2021 Bronco OuterBanks. 2023 Bronco Badlands, 2025 Volvo xc90
I have 2 Broncos. One with and one without and the one with it is so much better. It is super handy and in makes the floor flat
when you have the rear seats down which makes it so much easier to load and carry things. Does not make a noticeable difference in storage. Great help for doing work or if you need to stand on something or even a place to sit.
Rocki
The ford slide out tailgate was one of the first things I added to my 4 door after. As mentioned above, it levels the floor which is actually very nice for hauling larger items. I use it all the time when the bronco is loaded for camping, skiing, etc. it’s fantastic for getting toddlers ready, or as a spot to organize gear, or for tailgating.
I will say it is frustratingly expensive to buy as an accessory instead of a factory option, but if you watch carefully sometimes the ford discount codes aren’t capped at $1000, and you can get a full 20% off on them.
CitrusBronco
Everglades
Citrus county, FL
Everglades
The 2 previous posts say it all. I recommend it also.
EgreenBadSquatch
Washington
2015 F-150, 2022 Badlands Sasquatch
Really? I don’t think I’ve seen any not capped. If there was one not capped this would be on my list.
Footer
2023 Bronco
I could be wrong but I believe the discount is capped at $1,000, not the price of the item you are buying.
Rocki
You are correct, you can still spend over 1000 but will only receive the 200 max. The code I used had a higher max discount when I bought it a year or so ago
EgreenBadSquatch
Washington
So right after I made my post, I saw on another one with the code shop825 which does not seem to be capped.
Footer
2023 Bronco
Got it, my bad.
Seppy
Amy
Ford Bronco
Thanks everyone! We decided to order it with our build. Now, we need to find an after market cargo cover because Ford’s cargo cover won’t fit with the slide-out tailgate. Any recommendations?
Rocki
The slide out had a slightly rubberized texture on the top. I had 3w floor mats before I installed mine and just put it on top, fits just fine
CitrusBronco
Everglades
Citrus county, FL
Everglades
the slide out tailgate does not need a cover, it has a hard cover with a rubber like coating that is non slip. It’s pretty darn good, nothing will slide on it and you can lift the cover off and sweep it off when it gets dirty.
VirginiaHeritage
Frank
‘25 Bronco HE
100% worth it.
Wouldn’t have ordered it myself but the dealer had already installed it when I bought my HE. Having used it for a while now, I would never give it up.
Glade Runner
Everglades
VA
Yes
Everglades
If it’s not too late, see if the dealer can add it to your build. Much cheaper than adding it later.
I ordered my Everglades with the dual tops so they wouldn’t include it on mine so I had to install it after delivery.
Fuzzy Nuggets
Dan
Houston
2021 Big Ben 2dr., 2022 Raptor Code O, 2023 Badlands 2, 2024 Everglades
I need help. I recently bought the slide out tailgate off of Facebook marketplace, but the plastic trim piece did not come with it and unfortunately it’s a must have to access the slide out tailgate lever…. Does anyone know how I could order just this part? I marked it with the blue tape for reference..
Ford Bronco Slide-Out Tailgate imag
