IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
600lbs caught my attention! Is it mounted to the frame!?!?
That's pretty crazy considering all manufacturers are super conservative these days.
My guess is it probably bolts down using the stock tie down rings locations.
sanford
sanford
Ross
Columbus
Chevy Silverado, Subaru Crosstrek, Bronco
it’s like the extended the tie downs up 2-3 inches. It supports a lot of weight
sanford
sanford
Ross
Columbus
Can you post some pictures (and maybe add them to your original post) on the tailgate folded away? Curious if there's something that holds it closed securely so when you hit the gas, it doesn't slide out and into your rear door each time.
It’s completely locked in place when it’s stowed or extended. No sliding back and forth.
sanford
sanford
Ross
Columbus
Can you also post a pic with the back row down? I want confirmation this actually creates a flat surface to sleep on. Thanks! Also, I know Ford site won't let you add this and the tailgate table, but I imagine a tailgate table would be fine with it as long as you have the tailgate open all the way (beyond the 90 degree angle) because then the table wouldn't touch the slideout. I might end up getting that aftermarket, as I added the slideout already to my order, which is exact same as your rig besides the color. Enjoy!
Ford Bronco Slide-Out Tailgate Table Delivered!!! 53021E85-9549-496B-913B-314F0BA5C9B6
Totally flat load floor.
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
This gives me so much confidence in my storage drawer/tie down/subwoofer box plan I'm working on.
sanford
sanford
Ross
Columbus
I think even the standard ford storage box would work
gryphon1231
dj
Miami FL
na
Came directly from factory with my Black Diamond 4-dr
top is removable and fold up
I have that option for my WT. Hopefully it's still and option when they get around to building it.
friethmiller
Everglades
Fred
Austin, TX
2013 F-150, 1974 Porsche 914, 1974 Porsche 914 LE
Everglades
Sweet! I ordered this when I switched to an Everglades. Was a little concerned it might be delayed or cause a delay in my order. Good to see one in action. Can't wait. Thanks.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Please tell us about the rear security drawer, is it an aftermarket item? Website?
It’s on the build and price, I have one I’m trying to sell. It was dealer installed and I don’t want it.
(follow the chain people, this is in response to a security drawer that was asked about, not the slide out table /facepalm)
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
The slide out looks nice and doesn’t look like it takes up too much room and you should still be able to store the doors in the back.
Delli555
Massachusetts
GMC Acadia
B&P doesn’t allow you to order on-board storage bags with the slide out for the BD and I am guessing other trims are the same. Probably more of a height thing than a weight thing, so I believe my dealer has to order me the other door bags instead once I added the slide out.
Bryced15
Tennessee
Mustang
It says on Ford’s B&P that it “Prevents on-vehicle door storage”. I really want the slide out tailgate option, but wonder if I might want to carry my doors in the back. The thought of carrying the doors seems cool, but then again I may never actually do that. It‘s a tough call for me.
Cogentfire
Chuck
New Mexico
Exactly what I’m looking for to make the back area sleepable with air mattress. Thanks for sharing!
