Size Thread / Bolt Pattern on front bumper?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Update: I posted this in the wrong forum. This was supposed to be in the exterior mods area...
So with regards to the accessory mounting bolts on the front of the modular bumper.
Does anybody know the thread size/bolt pattern? I'm mainly interested in the 3 bolts in the lower opening, but I assume all of the bolts for accessories on the bumper are the same?
The factory bolt fit in an M8x1.25 thread at Home Depot, but after picking up some M8x1.25 bolts they don't seem to twist in. Is it actually M8x1.25 and the tolerance is just slightly off on the bolts I picked up?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Any Luck?
Ohh yeah sorry. It's an M8-1.25 bolt. If you want to match the head you'll want a TP40
I'd say a TP40 in M8-1.25x20 or 25 outta do for the length.
alexryer
Alex
Winchester, MA
2021 Bronco Black Diamond 4-Dr Soft Manual
Any luck with the bolt pattern on the 3 bolts in the lower opening? They look to be around 4" on center apart but I'm guessing. They also seemed pretty far forward toward the front edge of the bumper.
I was thinking of mounting a Rigid SR-series 6 inch SAE fog light in each pocket. But it seems maybe too short.
Ford Bronco Size Thread / Bolt Pattern on front bumper? 1637414213382
Would the Baja Designs S8 10" fit? Maybe a bit long.
Ford Bronco Size Thread / Bolt Pattern on front bumper? 1637414035874
Or maybe a Rough Country 8" like NorthShoreBronco posted:
Ford Bronco Size Thread / Bolt Pattern on front bumper? 1637412615837
Or similar posting by Bschurr:
Ford Bronco Size Thread / Bolt Pattern on front bumper? 1637413505750
Ford Bronco Size Thread / Bolt Pattern on front bumper? 1637412101234
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We already offer fog kits. The Baja Designs 10" is too big. But we've been offering (for about a month now) the Diode Dynamics 6" bars as part of a kit. We make a fog light mounting bracket already.
Lots of options here: https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
But the 6" Kit is here: https://www.4x4truckleds.com/diode-...-w-kr-off-road-brackets-for-2021-ford-bronco/
Our brackets are powder coated black, but what you see in the photos below is an unpainted aluminum one I was using to verify fitment.
Ford Bronco Size Thread / Bolt Pattern on front bumper? 1637426211984
Ford Bronco Size Thread / Bolt Pattern on front bumper? 1637426217836
Ford Bronco Size Thread / Bolt Pattern on front bumper? 1637426224296
Ford Bronco Size Thread / Bolt Pattern on front bumper? 1637426230202
