Patriotic
Peter
'22 Bronco Wildtrak; ‘25 Porsche Carrera Cab; ‘20 BMW X5
Question about the Ford Performance Tune - once installed, is it always enabled or active?
Sgoob
CO
Infiniti G37x, 2013 F-150, 2023 Bronco
No, you need to run premium. According to Ford Performance It can result in engine damage without it. I sold an Audi before buying the Bronco, and it also required premium fuel. There was not a single incident in which I could not find premium in 10 years of driving it, so I am not too worried about that.
Also if you are worried about it buy a bottle of octane booster to carry around, maybe not perfect but it will work if you cant find premium.
D&O
Derek
Seattle, WA
www.youtube.com
2023 Bronco / 2021 F150 / 1965 Mustang
That is what I did, I keep a can of RaceGas in the Bronco now.
Jossman
1979 F150,2011 Mustang,2013 F150,2006 HD
What is the best modification that you have made to your Bronco that you think others would also enjoy? For me it is easy, I added 6.5 inch back speakers. SSV Works has a rear pod replacement that converts the rear speakers to 6.5 inch Kicker speakers. I then added 4 inch Kicker speakers to the front dashboard. This has greatly improved the sound quality. Also, it was a super easy install, since they are plug and play on the rear speaker pod swap.
Oracle Fog Lights.Must have for mountain night time driving in inclement weather.
Ford Bronco Single best modification you've made on your Bronco!? ima
MNBigfoot
MN
Just turn the dial to Sport mode as opposed to having to carry around race fuel with you everyplace.
Stomper
Killearn
Jeep
Amazon sunglass tray. Fits nicely above the visor with a tab under the A-bar trim. I keep my vinyl case in there as a deadener, but am meaning to glue it down for when the top is open.
gaaangs
Ohio
Jeep
The dealership installed the tune and that subject never came up. I don't see any advantage to waiting.
How much was the tune from the dealership?
Tex
Cliff
San Angelo
The best octane boosters out there are lucky to raise a fuel like 87 octane up to 89 octane, and that's at their maximum mix ratio. Go beyond their max ratio and you will ironically start producing deposits inside the cylinder and spark plugs that will contribute to detonation and pre-ignition. It's also going to be imperfectly mixed, so your engine might see 89 octane for the most part and occasionally a little bit of 87. If you can't find premium, it's okay, just take on enough 87 to get you to a station that does have it, and take it easy until then. Our engines have very effective antiknock strategies baked into them, you almost can't make them damage themselves with detonation, they'll just keep pulling more and more timing and boost in order to prevent knock on low octane. It's a closed loop, so it sees in real time whether the adjustment was effective or if it needs to pull more, but it's also a reactionary system which means some semblance of a knock has to occur before it reacts. Timing changes are near instant, but it takes the system a moment to lower boost. You generally won't notice anything happening other than maybe it wasn't quite as peppy as you remember. For the most part this only happens when you're really giving it the beans with high levels of boost and/or aggressive timing (high RPM)...but higher octane is mostly unnecessary with relaxed driving where you're not pulling much boost and the trans is keeping RPM low. Tunes normally don't affect the antiknock strategies of an engine except in extreme cases, tunes do provide the conditions to reach detonation more readily, however. Best to simply stay off the throttle and avoid that part of the engine's operation where higher octane is necessary, whether you use an octane booster or not.
JonDW29
Jon
NoVA
'16 F-150
Damn you people and this f'ing thread. Now I got to go get a performance tune...
Yeah this thread may have pushed me over the edge as well.
As for what I've already installed, I'd say pocket lights so far but I'm just getting started.
Richterman
Badlands, Superduty
huge difference on the 2.3 auto
BD6G
Everglades
IN
24 Bronco
Everglades
Currently my favorite mod has been adding OEM signature LED headlights to my Black Diamond.
I have a few other goodies - light bar, grille letters and other smaller components sitting waiting on installation I just need the time and weather to do it.
I like the IAG soft top struts but I have experienced that it is a lot harder for my top to lock down and for the reinstall of the window panels. The buckling is now a pain as well and I am debating taking them off.
Quitefrankly
WA
Ford Performance tune - hefty cost but feels like a working non clunky vehicle now. Had it for a week and it's a night and day difference in 2d and even Sport has noticeable rev changes for the better.
Also the must needed combo of IAG front flaps + DV8 2021-2023 Ford Bronco | OE Plus Series Side Steps.
Think both of these in some equivalent package (a tune + a way to step up into a massive vehicle and protect rocks) is necessary.
  • Like
Reactions: D&O
