NJNMDoc
Southwest
Bronco Wildtrak
I still wouldn't mind getting an adjustable track bar, or at least one with more flexible bushings, but relocating the bar made it almost parallel to my axle, and body roll was significantly reduced. RJ says it corrects the roll center geometry, which I am not very familiar with, but it did make a huge difference.
Ya for $100 post lift I think that’s worth it. Install was easy? Looks pretty straightforward.
Brian514
Brian514
2022 Ford Bronco Badlands
So far for me it's between my full custom stereo and my air compressor.
The stereo adds greatly to my daily enjoyment, but I use the air compressor all the time.
Did you do the under hood air compressor? I really want to add one but am nervous about the install.
Brian514
Brian514
Easily the Raised Lid Cargo Enclosure from Ford Accessories. Being someone that drives topless from March to October, this is a no brainer. The obvious benefit is being able to lock tailgate and lid to prevent things from being stolen, but just as valuable is not having to worry about things blowing out of the cargo area at high speeds.
It does have some limitations but all said, well worth the cost if you're running w/o a top most of the year.
Thanks @RyanP for hooking me up!
Wow. That is nice. I’m in Colorado and my summer is about to start and I’m nervous going with the top off due to fear of someone trying to steal my bronco. 😆
Sitruc_btb
Curtis
Chandler, AZ
2022 Bronco Badlands
Yeah pretty easy. There is a spacer/collar that replaces the bar in the original mount position, and it took me some heel and pry bars, maybe a dead blow to get it mostly lined up to get the bolt through. Its a tight fit. Pretty straightforward install. Also comes with a brake line relocate bracket to make room for the bar bracket and hardware.
D&O
Derek
Seattle, WA
www.youtube.com
2023 Bronco / 2021 F150 / 1965 Mustang
Dumb question but what if you have the tune and you can't source premium? Does it just bog, not run right?
No, you need to run premium. According to Ford Performance It can result in engine damage without it. I sold an Audi before buying the Bronco, and it also required premium fuel. There was not a single incident in which I could not find premium in 10 years of driving it, so I am not too worried about that.
Cable Guy
Kurt
Audi RS7
Bestop Trektop. The EOM circus tent is not functional and looks ridiculous.
Bo-Ronco
Bo
HTX
2013 KR F150
I did. Twin ARB compressor. Install was very easy, especially with the AUX switches. 2 beer job.
Brian514
Brian514
I’ll have you install mine and I’ll give you two six packs! 😂
Brian514
Brian514
So far, I've completed over a dozen mods and agree with the previous posters that the Ford Performance ProCal Tune is amazing. More power & torque with much smoother shifting in just 15 mins. The only downside is that you need to use premium gas once you perform the mod.
As a bonus here are 2 other practical, great mods:
1) Adding Sport mode to a Badlands with Forscan, giving you every available driving mode
2) The Interior LED Dome Light Kit From IAG (Not only does it give you much more light when the doors open but you can connect them to an Aux switch and light up the interior whenever you need it)
Yes. Forscan is great, I was so happy to be able to add Sport mode to my Badlands. That is the mode I use the most. Also, added Bambi mode and removed the beep when exiting vehicle with fob.
Matsterious
Matt
Houston TX
2022 Ford Bronco
I'd add the Kicker Key Amp and speaker replacement made a huge difference to the enjoyability of driving it. The original sound was just so muted.
2door
AA
!!!FOR SALE!!! 2022 Bronco® The Sasquatch™ 2-door
CyberOrangeBadlands
Joe
Long Island, NY
‘22 Bronco
The Archetype Racing Magnum Stirrups.
So much easier getting in and out of the Bronco. Also extremely helpful in getting gear on & off the roof rack.
Patriotic
Peter
'22 Bronco Wildtrak; ‘25 Porsche Carrera Cab; ‘20 BMW X5
Top 3 mods in my 2DR Wildtrak with B&O:
1. Replacing rear speakers with Focal 4";
https://www.crutchfield.com/p_091ACX100/Focal-ACX-100.html
2. Replacing right and left dash speakers with JVC 4"';
https://www.crutchfield.com/p_105CSDR421/JVC-CS-DR421.html
3. Installing coat/hanger hooks from Etsy
https://www.etsy.com/listing/140255...c9-SUml8F&eaid=401739103173&x_eaid=2c2fe16894)
Honorable mention goes to how well Adams Advanced Graphene Ceramic Spray Coating took to my Eruption Green paint finish.
https://adamspolishes.com/products/graphene-ceramic-coating™-advanced
Ford Bronco Single best modification you've made on your Bronco!? IMG_1071
