Simple Garage Hardtop Removal
broncoky
Jacob
Lexington, KY
2021 Bronco 2DR CB OBX SAS & 2000 Lexus LS400
We had some beautiful weather today.
I was determined to figure out something simple and affordable for removing the hardtop rear cap on my 2 door Bronco….
I also wanted to be able to do this solo.
I found inspiration/copied the concept from this video. For my 2 door, the ceiling measurements I used: 68 X 48 inches
I used the mounting bracket for the front straps.
I know this is not intended for long term storage. I plan on using this for a single day like today. The longest my hardtop would be hanging like this would be for 3 days max.
Ford Bronco Simple Garage Hardtop Removal B6D03FC5-ECB1-4AE9-9A3E-CDA95888E66A
Ford Bronco Simple Garage Hardtop Removal AC7D7493-E671-4AF3-96F8-05B22D4FF565
Ford Bronco Simple Garage Hardtop Removal 85E73E0C-FE52-4B7B-8E2E-890CDA1EB078
Ford Bronco Simple Garage Hardtop Removal E84FA8F5-6F5E-43CB-A882-8FBBEF5C8AE0
webspoke
Stan
Pilot Point, TX
F450, GT350
Pretty ingenious, good job! 🍻
BlueBronco
DFW
Obligatory, I assume your ceiling hooks are anchored into joists/rafters/trusses?
Looks good. I had a similar set-up for my 4-door Jeep and would leave it hanging there for weeks. Only difference is I used one long strap for the front and one long strap for the back. That way, after the topped was hooked, I was raising and lowering from one side. Would just crank it up a bit and then pull the strap to equal the lift on both sides.
broncoky
broncoky
Jacob
Lexington, KY
I have been thinking of the same thing. Looks good. Where exactly did you hook the front? any pics?
The rear cap is secured at the top of the Bronco with 2 bolts you have to remove before taking it off. I just hooked into the mounting bracket where the bolt goes. Look for a Bronco hardtop removal video on Youtube and you will see what I'm talking about.
broncoky
broncoky
Jacob
Lexington, KY
Yes, all 4 screw eyes are connected to trusses above. I used a stud finder to approximately locate the center.
I think you posted a photo of your setup in another thread and is what got the ball rolling for this.
I jumped on this setup because all the weight is distributed to 4 points. Slightly lifting each corner, hooking and then tightening up the cam buckle on each corner was an absolute breeze. I was kinda shocked/proud of myself when I got the top off yesterday. The guide pins make reinstalling a cinch too, I just worked it down slowly on all 4 corners lining up the pins. Also, fairly minimal scars on my smooth ceiling/finished garage if I ever need to remove the screw eyes and patch up.
Removing/reinstalling the bolts is what takes forever when using the provided tools. I went ahead and ordered a cordless ratchet on Amazon to take care of that.
Knowing I can do this on whim and by myself will allow me to enjoy the Bronco that much more.
mcinfantry
Lee
Louisiana
Badlands 2 door
What size are the bolts that hood the hard top to the bronco? Do you need a swivel or just a straight socket will work?
broncoky
broncoky
Jacob
Lexington, KY
T50
The tools needed are provided. I've just been looking for an excuse for awhile now to buy a cordless ratchet wrench. This was the perfect justification. ;)
ChrisB351
Shreveport, LA
I currently have a JKU wrangler. I have a toplift pro lift and absolutely love it. I dont have enough clearance in my garage for an overhead lift. The lift will also work with 4dr broncos but unfortunately it doesnt on a 2dr but they say theyre working on something. Its a bit pricey but if you dont have the ability to do something else its worth it.
Kcmiller
San Francisco
BMW
What about the Harken Hoist? Has anyone tried that? Seems a lot more challenging to install vs. this solution.
The Beaz
Shad
San Francisco
Kcmiller
San Francisco
BMW
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
Any worries about the load on those front mounting plates? Everyone else seems to be using straps under the top but I'm not a fan of the way they rub on the top seals. Your mounting point are much better but I wouldn't want to pull that front metal bracket out of the hardtop.
broncoky
broncoky
Jacob
Lexington, KY
@67BroncoG1
The bracket is heady duty and thick. I think it will be okay. All the weight is distributed to 4 points. Roughly 20 lbs each, but the majority of the weight is in the back.
I went ahead and made a wood support for the back. Since I bought a new to me daily, the Bronco is now officially a toy. I plan on keeping the Bronco in the garage with the top and doors off until early Fall at least. If it’s a nice day, she’s ready to go!
Ford Bronco Simple Garage Hardtop Removal DB18D91B-7F6B-4951-B52C-972E4DFAA191
Ford Bronco Simple Garage Hardtop Removal F13E1D0E-D637-4A43-BAD1-8009F501D237
Ford Bronco Simple Garage Hardtop Removal F837336C-23B5-4711-9BC8-CA45DA8B2154
