Should these be up higher? 2 door windows
fritobandito
TN
Flex/bronco ordered
There are no leaks that I have noticed with my windows, but I have noticed it seems like the passenger side is a lot more noisy than the driver side. I was looking at the windows and the passenger side is a lot lower than the driver side with the - I guess seal? should these be higher and more inline with the corner of the window? Also, the top seals near the top; look a bit different on the door and both seem to be split so I am assuming that is intentional.
Ford Bronco Should these be up higher? 2 door windows 20240323_185716
Passanger
Ford Bronco Should these be up higher? 2 door windows 20240323_185740
Driver side
Shane78
Shane
St. Louis
2D
Normal.
fritobandito
TN
Flex/bronco ordered
Thank you!
DirectHit
Brandon
Tennessee
23 Gladiator, 23 Badlands 4dr, 23 Wildtrak 2dr
Welcome to the world of Awesome Imperfection 😀
jrollo7
James
NY
Range Rover Sport
[QUOTE
Not normal. My 2023 BD 2 door.
="fritobandito, post: 2188430, member: 58217"]
Passanger
Driver side
[/QUOTE]
Passanger
Driver side
Passanger
Driver side
jrollo7
James
NY
Range Rover Sport
[QUOTE
normal.
Passanger
Driver side
[/QUOTE]
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
On your note of passenger side wind noise, it’s predominantly from the roof seal here.
Ford Bronco Should these be up higher? 2 door windows IMG_6405
I’ve added in some extra weatherstripping to fill the voids and fatten up the contact areas.
The seal is often too short on length and height, and doesn’t fully compress to be effective
fritobandito
TN
Flex/bronco ordered
I will try that!
