Short Throw Shifter options?
Aman
Aman
Northern NJ
Hey guys, without any further delays please check out our brand new Bronco Short Throw Shifter it is currently live and IN STOCK!
https://www.boombaracing.com/bronco-short-throw-shifter/
For those of us who already purchased your knob, are you going to have a version without the logo and offer a discount? It's already priced significantly higher than your other offerings and early purchasers of your shift knob are getting screwed on price.
Aman
Aman
Northern NJ
IF someone previously purchased our shift knob please message us and we will be more than happy to offer a discount code so you guys are not left behind!
Thank you!
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Just PM’d you now with my order number
cant wait to install it
Jawaburger
Champaign, IL
2022 Bronco, 2 Door, Manual, Cactus Gray
What????? Isn’t that an oxymoron???
The throw is how far you have to move the stick/lever/shifter arm to change gears. The stick/lever/shifter arm is device you use to change gears. With a shorter throw, you have to move the stick/lever/shifter arm less distance to change gears. With a longer stick/lever/shifter arm, you do not have to move your hand as far from the steering wheel to grab the stick/lever/shifter arm to change gears.
So, let's go back to my original statement. The shifter arm will be closer to the steering wheel making it quicker to grab, and depending on throw reduction, I will have a similar or shorter distance to move the shifter arm to change gears. It's a preference.
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Anyone get it yet, install it?
ChrisakaMrXD
Queens, New York
2022 2.3L 2-Door Manual
I should be getting mine tomorrow. Probably gonna install it sometime this weekend.
ChrisakaMrXD
Queens, New York
Got it installed and drove around for a bit. First impressions, I'm extremely pleased! I had purchased the weighted shift knob before the short throw, which increased the length of the shifter, thus slightly increasing the throw. The short throw gets the length back to what the original shifter felt like, but the throw is noticeably shorter.
Installation was a little rough on certain steps, but this was my first time installing anything like this on any vehicle. The troublesome spots I ran into personally were the detaching the shifter cables from the shifter, removing the spring clip, and re-attaching the side shift pivot pin to the side shift bushing.
