Sherpa air compressor box
98infinity
Alberta
16 F150, 20 Road King, 22 Bronco
dadjoke
Southern California
'22 Bronco Big Bend 4-Door 2.7 MIC Auto Sasquatch
I believe there are numerous out there for a better deal, even in CAD. Amazon has a bunch. gimme a minute here
Edit:
This is one a bunch of forum members go for
https://www.amazon.com/ALL-TOP-150Psi-Compressor-Portable-Heavy/dp/B08637KCWQ/ref=sr_1_13_sspa?crid=3PP7OOM0SGI93&keywords=portable+compressor+box&qid=1703014494&sprefix=portable+compressor+box,aps,188&sr=8-13-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY&th=1
Edit 2:
Don't forget Tricky Mike, a forum member with his own site for fairly priced accessories
https://td-distributing.myshopify.com/collections/automotive-inflation
HoosierDaddy
__ Eric
NW. Indiana
Seems awful pricey unless that is a name brand compressor that has a stellar reputation. (Edit ... Sherpa is Australian, seems to be a pretty heavy duty unit, with a mini-air tank to boot, interesting ...might be worth the big $$$)
Ford Performance has an ARB box compressor as well.
https://accessories.ford.com/arb-fo...777986!!20643481100!157311292289&gad_source=1
There are plenty of cheaper versions that have been put to good use out here, as noted above.
The Trick-flate was the first thing that came to mind.
With a lot of these pumps, it is key that you are airing up more than one tire at a time, so getting a dual or quad set up seems to be key to keeping the compressor happy and running for a long time.
At that cost, I'm thinking I'd look into a vehicle mounted ARB at that point.
Felix808
SRV CA
Fishwrinkle
12 GC overland 5.7, 18 GC srt 6.4
it is a twin, but i'd still go arb
Felix808
SRV CA
I see that now. I only saw the 1 head at first 🙄 But yeah ARB is in the price range if you are spending that kind of coin 🤔
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Edit:
Edit 2:
Completely different animals...the Sherpa is not just the compressor it has a tank!
