Separating MIC top ??
joeb
Pennsylvania
FJ Cruiser
So, not sure if this is cosmetic only or going to allow water in.
Passenger side rear passenger panel meeting up with rear panel looks like black foam under the top
Ford Bronco Separating MIC top ?? 20230226_202347
The driver side is flush with gasket
Any thoughts
Thanks
Desert_Brush
SoCal
2015 Mini Cooper
It's not supposed to look like that. You may want to check that all the small levers are locked properly. It could be a bad picture angle. Can you please provide more pictures (perpendicular level, perpendicular from above, one from a bit farther)?
joeb
Pennsylvania
FJ Cruiser
Let me check the levers. Also it's been raining for a couple hours. Gonna check if there is any water inside -- when I leave work
Classic28
Brandon
Maryland
Nissan Titan
Any thoughts
Thanks
Last week I noticed mine was like this also, not sure if it’s been this way the whole time though.
joeb
Pennsylvania
FJ Cruiser
Well, truthfully not sure myself. But, I am very anal about things not being symmetrical, so I think mine is new and maybe related to the Cold weather.
On a good note, I checked this evening after work, I could not detect any water leaking in.
Nothing was wet/damp on sound deadening material, or no visual water inside or dripping near that area.
I will check in the morning. Will definitely inform dealer when I take it for first oil change next month.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Any thoughts
Thanks
Hi, Joe! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this roof top concern for you? Thank you!
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
I got the same thing going on, no leaking as well. The middle panel appears to be be bowing out at the edges. I think there's too much latch pressure and over time its reshaping itself.
Was like this new |---| now its like this /---\
joeb
Pennsylvania
FJ Cruiser
Message with requested info sent. Thank you.
