Seatbelts marking up door panels
Parker0076
Wisconsin
2021 bronco Sasquatch
Anyone else having the same problem? Seems like when you undo the seatbelt and let it go, it marks the door panel?
Ford Bronco Seatbelts marking up door panels IMG_1968
Wolfeman
Little Rock, AR
2019 F150 Raptor
My marks are more on the b-pillar plastic.
And definitely more concentrated.
HoosierDaddy
__ Eric
NW. Indiana
Do not even blink in the direction of the interior plastics, it will scratch it.
I think I've been using a 303 product to clean it up , it helps hide the marks.
Nothing special, just a standard plastic/vinyl cleaner conditioner, like Armor-All.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
303 is amazing. I use that on my fender flares and the wife’s exterior vehicle trim too. Highly recommend!
Bronco_Skillz
CT
BMW X3
RHeinz
Ric
Houston, TX
You must have a 2 door. As noted above it marks the B-Pillar on the 4 doors.
RHeinz
Ric
Houston, TX
I have been using this stuff since it was included with the Molle bags from Ford (though not sure why).
Ford Bronco Seatbelts marking up door panels F4B88D8B-38C2-4572-86F6-466C2413D5D3
It seems to hide some of these scratches and works well on the fender flairs. It was free so not sure what I’ll do when it runs out. 303 Protectant is on standby….
Reese
Reese 💁🏻‍♀️🇨🇦
CANADA
Bronco Badlands Lux 2023
Does 303 have any UV protection as well?
~Reese
604Bronco
British Columbia
www.bronco6g.com
j_marinelli
Spring Branch, TX.
604Bronco
British Columbia
www.bronco6g.com
Awesome. Thanks for the link @604Bronco!
~Reese🇨🇦
You're welcome - It's not greasy like cheaper products are, like Armor All. I just spray some onto a microfibre cloth and wipe it on. It goes on well, and dries quickly.
The wife's SUV has a lot more plastic trim on it and was looking very worn, and it's amazing what a difference this made. Here's a comparison:
Ford Bronco Seatbelts marking up door panels IMG_1826
the poacher
john
Whistler
2010 ford ranger
Hey Parker0076,
I definitely have this problem, and it not from just banging around, but by when you release the seatbelt as you stated.
Sadly, the interior plastic is amazingly easy to scratch. I believe the decision to use this plastic interior was driven by dollars and cents.
Reese
Reese 💁🏻‍♀️🇨🇦
CANADA
Haven’t had that issue. I have a 2 door and my seat is set a bit past the post forward. I do check periodically because of that and if I see anything it does wipe off pretty easily.
But as someone else said, it is easy to scuff pretty much anywhere in the vehicle. Not a deal breaker for me personally tho.
~Reese.
