Satsquatch vs territory MT PSI
stbanning
sean
Bonney Lake
f150 platinum, mazdaspeed miata
Not sure if this had been discussed someplace else but I was looking at the tire door sticker on a few pics that had been posted and compared them to tire rack and the goodyear website. The 315/70/17 territory MT is rated 35 psi max pressure on their website and the door sticker recommends running 39 psi. I must be missing something...??
Ford Bronco Satsquatch vs territory MT PSI Screenshot_20210716-173554_Chrom
Ford Bronco Satsquatch vs territory MT PSI Screenshot_20210716-173629_Chrom
BroncoKong Jr.
Andrew
Tire manufacturer's specs will (almost) always differ from the vehicle manufacturer's. Use Ford's suggestion, not Goodyear's.
Hopeless Diamond
JR
Chumstick, WA
F350/2dr Rubicon/'96 4R/'02 Silverado 1500/'22 Badlands
Ford's is based on gaining the highest possible gas mileage
stbanning
stbanning
sean
Bonney Lake
While I understand optimum pressure for on road and off road use... a factory tire pressure should never exceed tire pressure max listed by tire manufacturers spec. I do not belive that I have ever seen a factory recommended pressure exceed tire manufacturers max pressure. If max pressure from tire company is listed as 50 psi you would go by ford's recommendation to run 35 front and 38 rear as an example. Running a little less or more will change wear patterns on tire but not exceed max listed pressure
balucipher
Balu
Coral Springs, FL
'21 Bronco
The territory's on the Bronco may be a custom Ford spec that differs in ratings from the tire you're looking at online. Check the tire sidewall
Silver-Bolt
Eureka, MT
What does it say on the side of the actual tire? The max pressure will be printed on the tire.
stbanning
stbanning
sean
Bonney Lake
I do not have access to one.. this is a picture from this forum. I haven't seen a squatch in person they only brought 2 through early this year and neither had squatch. Seems like it's a oversight.
chobit
Eddy
Seattle
Mini Cooper SE, MIata ND2 GT, Bronco Badland SAS
Just took picture of the spare tire on my Badland w/ 35"
I am actually not so sure what that means by up to 10 psi additional means exactly.. maybe 35psi + 10?
Ford Bronco Satsquatch vs territory MT PSI IMG_1314
HBTFD
Newnan GA
F350
Go by what’s on the tire. The tire spec on a website can change dozens of times or be loaded incorrectly. The molded in spec on the tire is what the spec was when the tire was manufactured.
