Sasquatch tires possibly very light
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
By way of comparison the GoodYear Duratrac in the same 315/70R17 size weigh 61 lbs. and are D rated. They are a great tire, but are not known to have the best sidewall durability.
I ran Duratracs 315/70r17 on my Jeep Rubicon and loved those tires. Took them to Colorado, Moab and also ran the Rubicon Trail as well as being a Daily Driver and those tires had no issues on any of those trails, I did get a nick out of one sidewall In Moab but no puncture.
It appears to me the Goodyear MTs that come with the Sas Bronco are probably similar to the Duratracs but with a bit more road friendly tread pattern and load C as opposed to D.
srick76
NJ
F150, 69 Bronco, Durango RT
Heavier tires require more energy to rotate. So, gas mileage and engine load are impacted.
And wear and tear on steering components.
IXFE
Shelby GT350
So the Sasquatch tire is the new Goodyear Territory MT.
This tire is already available in 265/60/20 on Tire rack for a wight of 42 lbs in Load C range.
The popular BFG KO2 are only available in E load range for this size, at 57 lbs.
However, I could compare 2 KO2 of the same size (285/70/17) in both C and E range to see approximately how much E range adds in weight. The answer is 7lbs so we can safely assume a KO2 in 265/60/20 would be about 50 lbs.
What that all means is that a Goodyear Territory MT would be approximately 20% lighter than the exact same (size and load) KO2. Very good news if true.
Of course this relies on Tirerack spec accuracy. But I am sure the Territory will be soon available in 35" anyway because the TRX is out and uses those.
The TRX and the Bronco have different tire sizes.
TRX =325/65R18 = 34.6 x 12.6 with 8.3 sidewall
Bronco = 315/70R17 = 34.4 x 12.4 with 8..7 sidewall
kodiakisland
Arkansas
My Bronco will have E rated tires and I'm not weighing them. ?‍♂
Hoofnmouth
mark
N ca
ford focus st
hi
Bad experience with BF K02 load range C after 2 years used on gravel road about
12 k the tire come soft on the sidewall at 40 PSI. and i blow the tire..... For me only load range E nevermind the rolling mass and gaz . when you blow a tire on a gravel road in the woods or trail it`s not fun at all . lighter tire is good on paved road only my opinion.....do`nt trust me try it and you remember me when you blow your tire...
If you plant to go on a mud bog you need super swamper. or gumbo monster mudder. but on regular off road a good load range E and you back home free of trouble.
TRACKTOY
But im going with the spare tire delete?
hi
TRACKTOY
Thats okay lots of interest in the spare tire delete.?
