Running wires through Active Grille Shutters?
bronco100
Colorado Springs
Ford Bronco 2022 2dr
I have lights mounted on a bull bar, for which the wiring runs through the front grille, through the active grille shutters and into the back of the engine bay so that I can turn them off and on using the Auxiliary switches.
Could this cause the active grille shutters to not function properly?
Aztec1382
Sam
F350
Just run under the grill
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Uh yeah. If you run it through them then it could cause them to not close or open properly.
Raptor911
Raptor911
Broadlands, VA
I have had my raptor shutters apart when relocating the ACC sensor and was surprised how flimsy it was. The motor that opens and closes the shutters is tiny.
Put slack in the wire and it will shut fine.
CheekyOldMan
Bar Harbor, Maine
2022 Bronco Badlands SAS
Theres a space right in the middle of the grille you can run them up through, you just have to take the grille off.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2021 AMB Bronco, 2021 CO Bronco
Personally ran wires behind bumper and up. Followed the factory harness.
