Rock Krawler leveling kit, lower spacers
Brettlil17
Brett
South carolina
21 f150
Has anyone used just the lower spacers to level your truck? Seems like it would easier to install vs the upper pucks. Doesn’t seem like many places are selling just the lowers, I’d assume the ride would be the same from pucks vs the lower spacers.
Ford Bronco Rock Krawler leveling kit, lower spacers 897C3A36-7D46-4461-B2F3-A625B6369771
Brettlil17
Brett
South carolina
21 f150
interested. Did you do this? I am thinking about the same thing.
No, I was kinda hoping to have bronco by now 😡….
if my ride ever shows up I still think I’m gonna give them a try.
Bikeric
Tulsa
2022 Badlands LUX on 37's
Unless you are using a coil spring compressor during the install, you will still have to remove the lower control arms. Unbolting the lower shock bolts alone will not give you enough space (in my experience) to simply add those shims between the shock and control arm.
Classic28
Brandon
Maryland
Nissan Titan
Looks like you also have to beat out the factory studs in the strut to replace them with the longer bolts in the kit. I had to do this with my rough country kit and it was a pita.
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
thats a good point.
How did you remove them?
Classic28
Brandon
Maryland
Nissan Titan
thats a good point.
Removed the entire strut, put my foot on the spring and smacked them with a bfh. Took about 5-10 mins for each stud.
JL8jeff
Ewing, NJ
So do you really need to disconnect the LCA (if you don't compress the spring) to install the 1" level kit regardless if it's upper spacer or lower spacer or both?
