Rigid 360 6” Install Question
TNTim
Everglades
Tim
Collierville, TN
BMW 4 GC
Everglades
I’ve installed 2 Rigid 360 6” to aux switches. Backlight to switch 4 (10 amps) and Drive Beams to switch 5 (10 amps). Had the drive beams on for 5 min and they blew the 10 AMP fuse. Indicated to be 4.85 amps per light, does this sound about right?
Has anyone else had this problem?
My Aux switch 2 (15 amps) is available but was hoping not to need it for these two lights.
Appreciate any advice/ feedback.
btw, the backlights work fine, no issue.
Ford Bronco Rigid 360 6” Install Question IMG_7962
Copperhorse73
Justin
Mooresville, NC
Unless your fuse was bad, probably best to just move em to the 15a. It’s never the best idea to max out amp draw on a circuit anyways, leave a little wiggle room and at 4.85 per light you aren’t leaving any room
TNTim
TNTim
Everglades
Tim
Collierville, TN
BMW 4 GC
Everglades
Thanks for confirming what I was assuming to be the problem/ solution. 👍🏼
