Reverse Lights
Lindy08
Cliff
Illinois
2009 F-150
I'm trading in my 2009 F-150 for this Bronco whenever Ford sees it fit to delivery it to me. Question I have is, my truck reverse lights were(are) TERRIBLE. I ended up purchasing a "White Night" reverse lights kit that mounts around my trailer hitch and turns on when I out the vehicle in reverse. It's been good but it looks pretty outdated and sorta tacky. I'm not a big light bar guy, I don't really like the aesthetic.
What other options are out there that are more modern looking and will:
A. Look Decent
B. Perform Well
C. Power on automatically when in reverse
D. Last
Thanks,
Cliff
Edit: price is not a concern
kodiakisland
Arkansas
Depends on the bulb, but I usually replace mine with the next wattage rating up. It will be easy to add rear lights as well since the aux switches are pre wired. I like additional lights with a separate switch so they can be turned on any time you need light.
Lindy08
Lindy08
Cliff
Illinois
2009 F-150
I understand that, I’d rather not have to flip a switch every time I want to reverse.
I also have no experience with LED tail lights, so, I’m hoping they are bright.
kodiakisland
Arkansas
If they aren’t bright enough, and they probably aren’t, superbright or someone else will have a higher watt rating replacement.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I have a set of plug-and-play LED lights on my Jeep JK. Plug directly into the factory harness and come on with the reverse lights. (There is a provision for wiring in a switch also.) Bolt to existing mounting points under the bumper
Im sure aftermarket will be quick to offer similar items for the Bronco, as they already offer them for a myriad of makes and models.
You can see the left on in this picture. Right one is obscured by the step
Ford Bronco Reverse Lights 797EB8CE-60EA-4FF3-8F35-06DE8B098029
Lindy08
Lindy08
Cliff
Illinois
2009 F-150
Are there brands people recommend?
rynomar
Ryan
Santa Fe, NM
4Runner
Relays are really handy for this type of install. You can wire it up to activate your backup light with the factory lights and tie it into an auxiliary switch as well. I am a big fan of the Rigid LED's and they have a lot of options as far as output, beam pattern, size, and color.
Johnny Mo
Westchester County, NY
teachu2shoot.com
What could be really slick is a light disc that clips in behind the spare and shines thru. Not sure what kind of a spread pattern you'd be able to achieve - but if you wanted to hide the lights that's the easiest place to do it.
Used2jeep
Massachuvian
2007 Crown Vic P71
Used2jeep
Massachuvian
2007 Crown Vic P71
Half of the work has been done here. Now it would be a matter of a) changing it from brake light to backup light and b) changing the lights to a more powerful and focused set of beams.
csj
Craig
17 Tacoma OR
On my Tacoma I have 2 rigid ignite lights installed in the rear bumper, wired so they come on with the regular back up lights, they are awesome. Haven't seen a good way to do that on the new Bronco. The rear bumper doesn't look to have enough room to the left of the license plate to recess mount one light (with the other one on the far right side no problem). The 2 angled areas below and to the sides of the spare tire are taken up with back up sensors. I'm not sure how a symmetrical mounting of two lights can be recessed into the rear bumper. Could always mount one or two over on the right side, but that would look odd. Someone might mount some lights in the openings of the spare tire, like has been done on some Wranglers. I'm waiting to see what the aftermarket comes out with. Possibly one very small led light bar mounted in the center under the spare tire? I haven't figured it out yet.
csj
Craig
17 Tacoma OR
Update: something like the Denali "DRL visibility pods" might work, maybe 2 of them mounted horizontally on the bumper
in the middle under the spare. They're about 4 1/2" long x 1" high x 1/2" thick. Not the best, but they should be easy to surface mount, about $50 each. not too bad to replace if they get smashed, and mostly out of the way.
Rick Astley
Up Doug's ass
d
The reverse lights on Ranger with the BLIS package (LED tail lights) are quite bright, great dispersion and do an excellent job of lighting the area where the camera captures.
I am expecting the LED tails on Bronco to also be excellent as they appear to be comparable LED configuration for the white (reverse) section.
Ford Bronco Reverse Lights ford-bronco-2021-119[1]
Ford Bronco Reverse Lights 2019-ford-ranger[1]
