Installed the TOR HD carrier this week and unfortunately, our Bronco is one of the ones with the non-coax cable, so the included easy extension is a nonstarter.
Am forced to cut and re-wire the harness with wire extensions.
I would rather not do this. Does anyone know if you can just buy the entire camera/3rd brake light harness and camera that use the coax and swap them in? Just not sure if there's a difference in the wiring harness from the BCM to the plug in the back where the camera/3rd brake harness plugs in that would preclude doing the swap, kind of like the missing wire in the Halogen tails that prevents a Signature tail direct swap.
I will attempt the splice if I have to, but I want to pick up a spare harness from Ford before I go cutting into one. Does anyone know the part numbers of both harnesses, the coax and non-coax versions? I have searched several parts websites and come up empty. The following part number is listed on a sticker attached to the stock harness. M2DT12663AE but I come up empty everywhere on that except some random eBay listings.
Thanks in advance.
Thanks in advance.
