Return to Goat Mode
EvenBiggerN8
Nathan
Anchorage, AK
23 Bronco
I cannot figure out if there is a way to leave the goat mode in the last setting used instead of having to acknowledge the pop up window to allow it to remain in the previous mode. Any help would be greatly appreciated.
I don't know that anyone has figured that out yet. You can add and remove modes, but return to last ... not yet.
cake
Georgia
There was someone working on hooking up an Arduino to the CAN bus to hack this behavior in, AFAIK thats the only possible way to do it currently.
adamruiz2001
SoCal
Ford SVT Lightning
Nope, bugs the hell at of me that it asked every time I started the vehicle, I now just leave it in normal mode šŸ˜”
I can say, if you install the Ford Performance Tune, you won't care so much that it always starts in Normal.
lakesinai
Charleston SC
Yes, you are correct, when you've been operating in a dialed Goat Mode, and you stop the engine, when you restart the engine, the computer remembers your previous setting for a few seconds. It asks you on a pop-up, "Keep the previous Goat setting?" If you dont press "OK" quickly, it reverts. Ford may see this as a safety feature. I usually miss the popup. Curiously, the car will stay in 4L or 4H. Thats usually enough anyway.
All this seems to be a result of the fact that a "Mode" is just a collection of computer settings. Shifting is all electronically actuated.
I think it’s more an EPA thing - I seem to recall reading somewhere that they do not have to do testing on non-default modes. But if you let a mode default on startup, it has to pass EPA and the mileage reporting NHSTA safety testing and everything.
But make it optional and a user choice every time and you can just put the default ā€œfor off road use onlyā€ sticker on it
da_jokker
Jeep Wrangler JKUR
I don't find it that big of a deal and no there is no fix for it.
However what really bugs me (And I think it's a oversight with Ford) is that say you are in Mud/Ruts and you are in 4L. When you start the Bronco and it askes if you want to stay in Mud/Ruts and you click OK, it freaks out because it wants you to go back to 4H (because that's the default). So you have to start the Bronco, go to neutral, let it shift back to 4H, just so you can press the 4L button again).
Now THAT'S a problem...not simple pressing OK when you start.
ā€˜21OBX
90Bronco19
2022 bronco outer banks
Strange thing is our ā€˜22 F250 at work will stay in the mode you were in upon restart. There is a time limit as I’ll notice the next day it will ask. But throughout the day many key cycles it will keep the selected mode. That tells me it’s possible. I just don’t know enough or where to look to change the setting.
dpequip
Pickens, SC
23 Bronco OBX 23 Maverick AWD F350 Flatbed 4X4
If this is truly related to EPA testing & published ratings, the F250 will likely be different if it has a GVW over 8500lbs (It should be) Trucks over 8500lbs GVW are exempt from stating fuel economy numbers and a number of other regulations.
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
This happened to me wheeling. The computer freaked I freaked t case freaked. It was a bad situation. Took me a bit to figure out how to solve it after it wouldnt let me shift t-case. All of my Jeep buddies busting my balls. Soooo i no longer turn off my bronco when wheeling in rock crawl 4L. If i have to turn off motor i switch back to Normal before shutting it off.
