Replacing 2022 LED Taillight
AZWildTrak
Doug
2022 Bronco
I had a momentary lapse of attention and backed into a pole. Good news, it didn't due to much damage, bad news it busted my taillight. I got a replacement off of ebay, I installed it, really a super simple job. But when I turn the lights on, this new taillight plays an animation which my other light does not do, and the turn signal doesn't work (or flashers). Looks the same as my other one, was sold as a 21-23 replacement light. Is there some config I need to run somewhere to make it work correctly? If I get it working, can I get that animation to work on both lights??? It is kind of cool :)
Thanks for any help,
Doug
Bronccraig
Craig
Orlando Florida
2009 Challenger RT Hemi Orange
Im guessing its not an ‘ OEM ‘ LED one but one that WILL fit as a replacement..seems like a 3rd party makes these but you’ll need 2..anyway thats my best guess
broadicustomworks
Hanging Rock, North Carolina
Hey that’s neat.
completely no help on the signal thing, but had to give it the “thumbs up” on the start sequence. That’s rad.
front signals still flash?
maybe you can play around with ForScan settings like the flush mount needs When replacing Sig lighting?
AZWildTrak
Doug
2022 Bronco
BroncoCraig for the win! It is not an OEM light, it looks so similar I didn't even consider that. It is an Archaic taillight replacement for either LED or the Halogen taillights. It has switches under a rubber cover on the back to set it for which type of light it is replacing and also what sequence of animation. The animation sequence that was set is called Breath Mode. Turning to Scanning Mode makes it very similar to the stock taillight but not identical.
Thanks for the idea Craig, it helped a lot.
Archaic New Car Lights For Ford Bronco Taillight 2021-up Plug and Play - BRONCO - Guangzhou Dingyun Information Technology Co.,Ltd (archaic-official.com)
