Replacement valve stems
Tricky Mike
21 Bronco
Just an FYI for anyone needing valve stems, I've just personally installed these and can confirm they work with our TPMS sensors.
Ford Bronco Replacement valve stems Screenshot_20240318-101316
Felix808
SRV CA
Are they flexible or are the ridged like the factory stems?
Felix808
SRV CA
Too Bad.
Richard @goatman2 had a great solution where he banded the TPMS senor in the center of the wheel & replaced the stems with short soft / flexible valve stems. That way if you ever cut one on the trail it could easily be swapped out with a cheap replacement.
