Replacement rear soft window plastic fastener?
mdk77
BM
Illinois
Bronco Base SAS
The right long fastener on my rear soft window cracked. This is the piece that the side window seeds into - the channel is cracked. Is it possible to replace that channel only or does the entire window need replaced?
See picture for reference
Ford Bronco Replacement rear soft window plastic fastener? IMG_1938
trail-walk
Zach
United States
trail-walk.com
6th Gen Ford Bronco
Ouch, that’s a frustrating spot to crack.
Unfortunately, the bad news is that on almost all of these soft tops, that plastic retainer channel is permanently bonded/molded to the window panel itself. The manufacturer doesn't sell just the plastic track separately, so the official fix is replacing the entire window panel.
tip: If your rig is relatively new, definitely check with your dealer first to see if it’s covered under your bumper-to-bumper warranty 🤔 . Good luck!
Area51BS
Ron
Badlands non SAS 4dr 2.3
I believe it is ABS plastic. There is an ABS solvent cement. It’s water thin and applied with a syringe needle style plastic bottle. Hold the two halves together and let the solvent flow into gap. Hold for a minute. Good as new.
mdk77
mdk77
BM
Illinois
Bronco Base SAS
Awesome thanks all I’ll try it
