Replacement Bolts for Heavy Duty Modular Front Bumper?
p3pete
Pete
Newport, RI
03 Cobra, 23 Bronco Raptor
Went to install some fog lights and one of the bolts is straight up missing from the bumper. Has anyone sourced the bronco bolts?
Cheers,
Pete
p3pete
p3pete
Pete
Newport, RI
Found the part number W72221447-S900. Ordered from TASCA. Leaving the thread up in case someone else needs the same part... 3 bolts each side.
Update: Thanks to no1hedberg who found the correct part number... see his post below...
unfortunate
NA
do you have a source for that info? Are all the bolts on the modular bumper the same? I bought a take off that’s missing some.
Skeener801
Trevor
2012 Boss 302, 2022 Bronco 2.3, auto, soft top.
W72221447-S900
Has there been a part number change? Searching for that on Tasca brings up no results
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Just searched the same and dont see it either @flip has this part number changed? I didn't see it on your site either
flip
Phil
IN
www.ruxerparts.com
Fords
https://www.ruxerparts.com/oem-parts/ford-end-cap-bolt-w721180s450b
https://www.ruxerparts.com/oem-parts/ford-reinforcement-bolt-w721447s900
The W72221447-S900 is the bolts marked as HB4, M8 X 23MM. The first link is the bronco bolts marked as HB3 in the pic. and M8 X 30. I really don't think 7mm is going to make much of a difference in the grand scheme of things.
Ford Bronco Replacement Bolts for Heavy Duty Modular Front Bumper? 1667941548340
Morrisattack
Hagerstown
BRONCO AND BRONCO
That is correct part number and it hasn't changed number's. Ford does have them but they're 9.00 a piece
derichio02
Bo
Southern California
I just ordered them from @flip and they are much cheaper! Would recommend clicking on the link posted above by flip if you are interested.
ar1
Norcal
4dr WT
Does anyone know the part number for the bolt marked "HB2" here?
It seems like I need 4x for each side but don't have all 8
flip
Phil
IN
www.ruxerparts.com
Fords
Edit: I think this is it -- W500741-S439
HB2 is W717964-S450B BOLT, M8 X 29MM
ar1
Norcal
4dr WT
Hm
Hmm - there seem to be two bolts marked HB2 in that diagram. I'm looking for the one that connects the four corners of the hook bracket to the bumper frame. I think its a 14 or 15mm
Ford Bronco Replacement Bolts for Heavy Duty Modular Front Bumper? IMG_2820
No1hedberg
West Virginia
2023 Bronco Wildtrak
If you’re looking for the bolts that have Bronco stamped on them, this is what you’re looking for.
Ford Bronco Replacement Bolts for Heavy Duty Modular Front Bumper? IMG_4701
Ford Bronco Replacement Bolts for Heavy Duty Modular Front Bumper? IMG_4700
The s900 part number is similar, but they are a few mm shorter, have no washer, and don’t have Bronco stamped on them. I spent a lot of money ordering the wrong ones. Just trying to save others some hassle.
Ford Bronco Replacement Bolts for Heavy Duty Modular Front Bumper? IMG_4707
thenewjs
Archie
Braptor
Thanks man does 4x mean there were 4ea per pack. I’m googling -W721180-S450B and descriptions are saying 1
No1hedberg
West Virginia
I think they come in packs of 4 but they are priced per bolt.
