Replace Outerbanks tires with Badlands?
NyVetteGuy
Basil
Westchester County, NY
2020 C8 Corvette / 2021 Jeep Grand Cherokee L
If I replace these:
Ford Bronco Replace Outerbanks tires with Badlands? 9FF923FA-A9FD-403A-AD27-3C7C34DA97BB
With these:
Ford Bronco Replace Outerbanks tires with Badlands? 125C98CA-0506-4A77-AECE-188EAA8145C4
Do I need to do anything else other than remove the crash bars? I don’t need to lift the truck do I?
Thanks in advance for the help!
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
You do not need to remove the crash bars, should bolt right on
RagnarKon
Ford Bronco, Escape, Focus
You don’t need to do anything at all.
You only need to remove the crash bars when you go larger than ~34” tires. The picture you posted is the factory 33” (non-Sasquatch) tires.
tongsun3717
X3
Need to recalibrate the speedometer, using Forscan.
NyVetteGuy
NyVetteGuy
Basil
Thanks all 🙏 what about the spare? Am I good with the third brake light?
tongsun3717
X3
A 285/70/R17 tire should be OK w/o raising the break light. I have it now.
Beachin 74
Delaware
The only thing you will have to do is trim the bumpers on the tailgate that go up against the spare tire because of the extra width of the Balands tire and wheel.
No need to remove crash bars or recalibrate the speedo as the outside diameter of the Badlands 285/70-17 tire is only 3/4" taller.
Ford Bronco Replace Outerbanks tires with Badlands? 2022-02-05 00.36.03
