Replace 35s w/steelies
Monument, Colorado
Ford Bronco Replace 35s w/steelies IMG_5994
- Definitely quicker, more nimble, and smoother highway ride
- I’ll post MPG in a week or so
- All lugs are torqued to spec
- Noise/grinding feeling in the steering column even after ABS Fuse #23 removal
- Noise/Grinding is only during slow sharp turn, or when steering wheel is whipped back and forth doing figure eights. Only the last 10% of full turn
Owl
G
Sacramento
White Wrangler JK, White Bronco Base 2Dr
Wow. Looks better than I thought it would. When you switch them back (with the steelies off) maybe you should paint the rims white for that Heritage look. I'm going to do that (if the lazy gene ever leaves me).
