Redline hood struts installed
stickshifthappy
RVA
Ford Ranger, 65 Mustang
Ford Bronco Redline hood struts installed 6BE37287-C43A-4E62-A270-678F3DD49578
Doesn’t take long, but it’s a tight fit inside the fender area against the hood bracket and bolt connection.
Dropped the wrench into the fender wall, but luckily unscrewing a few connectors at the plastic wheel liner allowed it to drop right out to the ground.
If not for that mishap it would have taken about 15 minutes to install both.
UTME
T-Roy
2024 Jeep Rubicon-X
Looks nice. I’m wanting to install same.
los7883
TX
Chevy Corvette
Looks good, just installed mine last week!
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
These are great struts. Had mine for 8 months and they are perfect. Easy install like OP says. Took longer to get them out of the packaging than installing. :)
MotoVexGT
Ahnamataeus
Seattle
Ford Bronco Badsquatch
Does anyone know if these struts (or others like them) interfere with engine mounted compressors, such as the vertical Grimm mount?
Gettyup
Rocky
So Cal
Bullitt Mustang, Expedition
I have the Redline struts and the Grimm compressor mount and No interfere. 👍🏻
AK007
Washington DC
Awaiting my Bronco
Love mine! Quick easy install, was one of my first mods!
Shawshank
Shandy
Canada
F250 1998
😂 I would have been like “Welp, I guess that wrench lives there now”
but that’s awesome! Does the hood only have a prop up bar by default? Cuz I will def do this mod if that’s the case, when I finally receive my bronco lol
stickshifthappy
stickshifthappy
RVA
Yes, all Broncos come stock with the hood prop.
For a second I was, "yep, that wrench stays there for life". You could tap the bottom of the fender and feel, and hear the rattle of the wrench a bit.
Bronco_Mo
St. Peters, Mo
2023 Outer Banks
I did the rough country, dropped one of nut inserts into the hood. took a magnet to get it out...I'm gonna try the soft top struts next...(iag) wish me luck...
helifino16
Ron
Mount Sinai, NY (Long Island)
This may quickly turn into a how to retrieve something dropped in the fender thread. I did it and it sounds like lots of people do. (LOL)
Thank goodness that this thing is as modular as it is. A couple of bolts and viola the nut dropped out.
BTW - Hood Struts RULE! one of the best mods I've done.
McCrosky2004
Ron
New Orleans La
2020 F350 SWR
Received mine last week and installed yesterday. Yep tight fit getting the lower mounts in, after reading post I put a shop rag to keep anything from getting in the finder. I know theirs not much benefit to them but also installed a hood isolator. I just like the way it looks.
Ford Bronco Redline hood struts installed IMG_5443
Redline Tuning
F-150
Thank you for all the positive reviews of our product! Our system is MADE IN THE USA with either 4 or 5 year warranty and our customer support will take care of any issues!
Free shipping in the CON. U.S. on all Bronco systems using coupon code "Bronco6G" at checkout.
We offer two different lift heights for the Bronco. Our standard QuickLIFT system raises your hood to the same height as the factory Prop Rod and our Max Lift system raises the hood 8 inches higher for maximum access to the engine compartment. Both systems are available in PLUS, Carbon and ELITE versions as shown below. There is no functional difference between PLUS, Carbon and ELITE, it's only the finish of the gas spring. That being said the Max LIFT PLUS is out most popular system.
Ford Bronco Redline hood struts installed bronco-maxlift-jpg-jpg-jpg-jpg-jpg
Ford Bronco Redline hood struts installed bronco-quicklift-plus-jpg-jpg-jpg-jpg-jpg
Ford Bronco Redline hood struts installed bronco-maxlift-plus-jpg-jpg-jpg-jpg-jpg
QuickLIFT PLUS features:
* All black powder-coated mounting hardware
* Black e-coated gas springs
* 4 year warranty
available directly from our website here:
QuickLIFT (same height as stock)
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-PLUS-p/21-11040-02.htm
MaxLift (8" higher than stock)
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-PLUS-p/21-11039-02.htm
Ford Bronco Redline hood struts installed bronco-maxlift-carbon-jpg-jpg-jpg-jpg-jpg
QuickLIFT CARBON features:
* Black e-coated gas springs with real carbon fiber sleeves
* 4 year warranty
To add the Carbon option check the box show below on our website:
Ford Bronco Redline hood struts installed carbon-jpg-jpg-jpg-jpg-jpg
Ford Bronco Redline hood struts installed bronco-maxlift-elite-jpg-jpg-jpg-jpg-jpg
QuickLIFT ELITE features:
* 316L Stainless Steel gas springs
* 5 year warranty
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-ELITE-p/21-11040-03.htm
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-ELITE-p/21-11039-03.htm
You can watch the video below to see how easy our installation is, the only tool required is a 13mm socket:
Here is a video of the different gas spring finishes and the system in action:
Redline Tuning has been developing our Hood QuickLIFT systems for over 20 years and have applications for over 350 unique vehicles, check out our website for your vehicle application.
