Recall 26s09 apim update - USB ERROR CODE0
jacopo
Jacopo
Italy
2021 bronco badlands 4dr 2.3cc
Good evening everyone, I'm writing from Italy. I have a 2021 Ford Bronco.
My vehicle is under recall for the APIM update, but the dealer tells me it can't complete it because it gives the USB error. They've tried with various flash drives, but there's no solution. They're waiting for a possible alternative from Ford.
I also have the FDRS software. I've tried the procedure several times by downloading the files and uploading the USB flash drive, but every time I insert it into the car, it still takes a long time to activate. It takes at least 10 minutes for the first screen, then it seems to start the process in percentages, but it doesn't progress, it always stays at 0%, and after another 10 minutes, the USB error appears.
Does anyone have any idea what the problem could be and what possible solutions there are?
I've already reset the module. The flash drive is in MBR format, formatted as Exfat32.
Many thanks, best regards
Jacopo
I didnt think you could update Sync 4 with a flash drive.
Or do you have a Sport and are in the wrong forum?
jacopo
Jacopo
Italy
It's a full size bronco.
Fdrs do have the procedure to do that.
