Rear Window Issue
broncolado
2024 Bronco Black Diamond
On my 2024 Bronco, the rear passenger side window doesn’t sit fully inside the top weather seal when I close the door. It looks slightly off until I roll the window down and back up again, then it seats properly.
It’s almost like the auto-index (the little drop and raise the window does when opening/closing the door) isn’t syncing right.
Has anyone had this happen or know if there’s a quick recalibration fix for it?
Ford Bronco Rear Window Issue IMG_5500
GoHawks63
George
Metro Detroit
2024 Bronco Wildtrak, Cadillac CTS-V Coupe, Roush Stage 3 Mustang convertible
Lower the window holding the button down the whole time and keep pressing the button for about 5 seconds after it has completely lowered. Then raise the window, again holding the button the entire time after it as raised for about 5 seconds. I would repeat the process one more time.
That should reset the index.
jtgensler
Jamison
Clarion, PA
2022 Bronco, 1996 Tacoma
It's literally the most common issue with the frameless doors/windows & the fix, as noted above is very simple.
f3d
dirty jrz
OBX 2.7 Squatch HT
Just wanted to add that, at least on my '21, while recalibration seems to correct it, any use of the remote/fob unlock+auto-down feature seems to totally F*** the calibration right back up again. Ive done this repeatedly back to back. Seems like something stupid happening in software with auto down (which I love but have stopped using)
