Rear washer on soft top?
Andrew
New York
2022 Bronco Black Diamond
Just took delivery of my soft top with the prep kit. Was trying to wash my windshield by turning the stalk (before I found the button on the end). My question is have I sprayed a ton of washer fluid inside the rear panels? Or is the line capped or something until I put a hardtop on?
Layman
Voorheesville
2022 Bronco Badlands 7MT
Following. LOL.
I have only done that once and did not notice any washer fluid in the back, but I did not really look either. It does have the fitting where it connects, but I am not sure if that is a drain, a cap or how it works.
HeliPilot
Kenny
CT
2022 2.7L SAS
Not gonna spray. If you don’t see a flooded cargo area, you’re good
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
The washer nozzle is plugged into a cap in the trunk area. The pressure isn't enough to spray around the o-rings that are part of the hose nozzle.
JR
‘21OBX
90Bronco19
2022 bronco outer banks
The connector on the back has a valve like an air hose. Nothing will come out without the proper fitting connected. The little nub it hooks to is not long enough to open the valve.
