- Eric
- Jul 10, 2021
- 41
- 1,326
- 4,423
- Sacramento, California
- 2017 Raptor
- Wildtrak
2021-2023 FORD BRONCO Bilstein Sasquatch Struts Rear set. Condition is Used. Shipped with UPS
https://www.ebay.com/itm/204722342074
2.7, two door.
They do have on them SVC collars which make them taller by two inches they can be removed. Can fit 37s no problem. Fronts 1.5"-2" Lift kit for Base Bronco's 12,000 miles on them.
21+ BRONCO BILSTIEN SHOCKS REAR, FACTORY TAKE OFFS, MAKE HAVE A SCRATCH OR SCUFF FROM HANDLING
If you compare photos from some of the ebay listings for the same shocks you can see the difference the SVC collars make, there is the yellow part of the body of the shock showing at the bottom of the spring perch. Like a stated before these can be removed if you so chose.
2.7, two door.
