Rear marker lights/tail light issue
V1Rotate
Brevard, NC
2022 Wildtrak
Can’t seem to find anyone else that has experienced this issue so I figured I’d try to give a few people some anxiety -
2022 Wildtrak / Signature lighting w/ poor-man’s mid package
Starting recently I’ve experienced several instances where my rear marker lights don’t come on with the headlights when driving in the dark. First time somebody rolled their window down and told me at a red light in town early one morning and its happened a few times since when I’ve been looking for it.
Kicker is that it’s ONLY the rear marker lights (whatever you want to call the red part of the tail light that comes on when the headlights are one). Happening on both sides simultaneously. The brake lights work, the reverse lights work, the turn signals work. The remedy in all 3 experiences has been to stop the vehicle, turn it off and open the door so the power dies, start it up again and cycle the headlight switch From auto (where it lives normally) to completely off then back through the selections to auto again. From then on they work like a champ until the next occurrence a week or two later.
Software is up to date
In all 3 instances it’s been dark.. not just dim. 3:30 AM dark
flip
Phil
IN
www.ruxerparts.com
Fords
No modifications, correct? DM me your VIN and I'll look at your VHR.
V1Rotate
V1Rotate
Brevard, NC
2022 Wildtrak
I’ve done a few simple Forscan mods (double honk, Rock crawl, amber DRL, rear speaker eq, seatbelt minder, TPMS threshold, etc) but that was about a year ago and had no issues until a few weeks ago. Stock taillights
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Johnny Mo
Westchester County, NY
teachu2shoot.com
I had an issue with my pass side tail light - the top half stopped working. Replaced the whole unit - sometimes it's just a bad LED board, but sounds a bit more involved on your end if it's both at same time.
V1Rotate
V1Rotate
Brevard, NC
2022 Wildtrak
Yeah it’d be quite the coincidence for both sides to act up in unison each time and also not lose any other functionality of the tail light. Love me a good intermittent electrical issue! Get enough of that on my wife’s jeep
2022obxblack
Jason
Raleigh NC
2022 Bronco OBX
New, to the forum, just got my Bronco last month. Yesterday I had the same issue. I went to pick up my daughter around 9pm and noticed my right side blinker was hyper flashing. Got out and saw my taillights were not on even though the headlights were. Back up lights did not work either. Left side blinker was fine. Totally stock as well.
V1Rotate
V1Rotate
Brevard, NC
2022 Wildtrak
That’s a strange one. In my case all other light functionality was totally normal except for the marker lights and it was uniform left to right. Were you able to get it working again?
2022obxblack
Jason
Raleigh NC
2022 Bronco OBX
No, I turned off the car and restarted it but it didn't fix the issue. But I'm gonna check this morning and try your suggestion if it's still an issue.
2022obxblack
Jason
Raleigh NC
2022 Bronco OBX
So I took mine in today and they told me I needed a new BCM. Should be good now. Now if they could figure out what is up the damn floor heat lol.
V1Rotate
V1Rotate
Brevard, NC
2022 Wildtrak
Glad you got the lights sorted out at least!
Headsong
I'm having a similar fast blinker on driver's side issue. All lights seem to be on...and it's been a little bit intermittent...I did change tails to Oracle LED's, so all lights should be LED's....and shouldn't go out?
