Rear hatch vibration/rattle over bumps.
Mad Martigan
Oklahoma
Fords (Bronco BadTrak, Expedition Timberline, Bronco Sport, Edge ST)
Anyone have a vibration/rattle noise over bumps? I've identified mine as the rear hatch glass. I tested it by opening the glass and driving around and voila gone. I'm thinking it might be the rear glass rubbing back and forth on the two bumper rests at the bottom? Or it's the entire glass vibrating in the frame of the top?
In any case just reaching out to see if anyone has a similar issue and a potential fix.
It's not super annoying but I don't recall it being there when we first picked up the Bronco.
Thanks!
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Thanks!
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
Mine makes a low pitched squeak/rattle, I solved it by applying silicone spray to the seal along the bottom of the glass which goes against the swing gate
BRBlue
Houston
Toyota Tundra
Common problem. Mine did it from day 1. Silicon spray on all seals as mentioned should help. It eventually stopped working for me and I applied Krytox silicone grease. Will last longer.
I still get occasional popping sound from the glass (hinges?) but the other noise is gone.
omg_bbq
Eli
Oakland, CA
www.instagram.com
2022 EG BD SAS
My soft top rattles some days from the rear. Recently something on the soft top has been cutting into the rubber on the passenger side where the soft top locks down in place.
Ford Bronco Rear hatch vibration/rattle over bumps. D99F71F0-9766-4566-9768-E2CD59451E62
Mad Martigan
Mad Martigan
Oklahoma
Thanks for the silicone spray tip I will try that. Temporary solution but at least it will hoepfully help identify the specific sea/areal that is most noisy if that is where it’s coming from.
Ground_zero298
Scs michigan
Any movement in the hinges at all where they mount in the top?
Brockdog12
NTX
2022 Explorer ST-Line
Stereo is always cranked, couldn’t tell you. 🤟
Mad Martigan
Mad Martigan
Oklahoma
Ground_zero298
Scs michigan
I will double check my hinges but I did not notice any.
Was just curious. Saw another member who was unfortunate and had his top drop a couple inches and land on the window. It ripped the hinge out of the top. After seeing how it was mounted I was wondering about the longevity of it.
Mad Martigan
Mad Martigan
Oklahoma
Got it. The window is hood no looseness. Checked the window tonight and the hinges are tight at all the connections.
Denny3297
Dennis
Wisconsin
Acadia, Ranger, Fusion, E450 motorhome, Focus
Hello Ford Motor Company! Mine does this same thing. It's really annoying! Help!
MikeD
Colorado Springs, CO
2012 Ford Raptor
We have the same issue on our Wildtrak, may try the silicone.
imstimpy
Austin TX
MY21 Badlands
I just noticed this as well. Only on the right side; not the left.
