Rear Hatch Key Detection Range Shorter After Trailer Harness Install
Haelous
US
2016 Mustang GT, 2023 Bronco Wildtrak
Hey guys,
I had my Trailer Hitch Wiring Harness (VP2DZ15A416A) installed at the dealer some time ago, and since then the detection for the rear key fob when opening the rear hatch has been significantly reduced. Trailer harness itself works great.
Is this normal?
Did they miss a step?
Thanks!
RagnarKon
Ford Bronco, Escape, Focus
There are multiple PATS antennas in the rear cargo area. They may have forgotten to plug the driver side cargo area antenna back in when they put the panel back on.
Bat signal for @Ducati1098 .... cause I know he has a picture handy.
Ford Bronco Rear Hatch Key Detection Range Shorter After Trailer Harness Install 1718901250989-e5
Haelous
Haelous
US
Oh boy sounds like I need to start taking the plastic covers off the driver's side cargo area. I'm much better with mechanical stuff than interior plastics so this will be an adventure.
Ducati1098
@Haelous
Not the best picture, but its near the rear top of the panel on the inside.
#2 in this picture
Ford Bronco Rear Hatch Key Detection Range Shorter After Trailer Harness Install 1718901711679-u7
Haelous
Haelous
US
@Haelous
#2 in this picture
This picture makes it look like passenger side. Is that right? Moar Doar Wildtrak.
Just checking since Rag mentioned driver side.
Ducati1098
Thats my bad, I copied the wrong picture. It is on the drivers side. Very similar though
Ford Bronco Rear Hatch Key Detection Range Shorter After Trailer Harness Install 1718901959908-xr
Haelous
Haelous
US
Thanks, big help knowing where all the clips are. I have an interior trim kit and some spares so I'll get to it.
Ducati1098
No problem. You may be able to carefully "peel" back the top corner to get enough room to reach your hand in there to see if it is plugged in or not.
Don't forget to pop this small plastic cover off first:
Ford Bronco Rear Hatch Key Detection Range Shorter After Trailer Harness Install 1718902275683-ih
RagnarKon
I you want even more of a visual... I got a video on removing the passenger side panel for a subwoofer install. Driver's side is obviously very similar and requires many of the same steps.
You probably don't need to remove the entire panel though. So... ya know... modify steps as necessary.
Haelous
Haelous
US
Just in case anyone finds this thread and needs another pic, the antenna is on the plastic trim panel.
Ford Bronco Rear Hatch Key Detection Range Shorter After Trailer Harness Install IMG_3350
