Rear cargo drawer system - JcrOffroad
Status
Not open for further replies.
JcrOffroad
JcrOffroad
Portage, Mi
2021 Ford Bronco Badlands
Any plans for a two-door version?
Perhaps in your future. We have a lot of other vehicle platforms to get floors developed for first. The numbers on 2-doors makes the pool of potential customers really small.
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
I finally completed my install this morning. Now I'm waiting on the lables to arrive. @JcrOffroad, do you know what this plastic trim is for?
Ford Bronco Rear cargo drawer system - JcrOffroad Ima
Ford Bronco Rear cargo drawer system - JcrOffroad 20230318_194418359_iOS
JcrOffroad
JcrOffroad
Portage, Mi
I finally completed my install this morning. Now I'm waiting on the lables to arrive. @JcrOffroad, do you know what this plastick trim is for?
We missed those in install doc. It’s for the drawer dividers.
Ford Bronco Rear cargo drawer system - JcrOffroad FCF8C431-56D1-4828-9EA0-04F17E5E94B7
Traveling.Gaijin
Emerson
Salt Lake City, Utah
2001 Jeep XJ
I'm still waiting for my bronco but the drawer/flooring system is going to be here on Saturday and it had me thinking.
Are you guys planning on selling the panels a la carte? Cost of doing so couldn't be too crazy, wouldn't even need to include hardware kits for them.
From videos and install guides it seems like the quickest way to change up the system would be to swap the plates all together. For example, to go from a camping setup to back to a slick floor, it looks like leaving the panels bolted to the drawer or slide and just removing the hardware bolting the panels down to the floor bracket would drastically cut down time and effort. In your videos, that hardware looks to be accessible regardless of what is mounted on the panel.
doyouglas
Douglas
Southern California
Toyota Highlander
What did you order? I have 2 10” drawers in my cart but waffling on whether to start with a 5 and 10. The initial plan is recover gear in 10. Wondering if 5 large enough for kitchen stuff.
How did you mount the slide out fridge and drawer. Is that plywood? It doesn't look like the jcr cargo base
ICUGAZN
Kevin
2019 Raptor
Yeah I made my own plywood platform. Sprayed it with a bedliner and they painted gray so that it somewhat matches the cargo interior. After letting it dry for some days I drilled holes to match my fridge slide and the drawers. I used these inserts in the holes as well. I can remove the fridge slide in a couple of minutes when I need the space for something else. The JCR drawers take a little more time due to the way the drawers mount inside of he shell. https://a.co/d/115aNLZ
Ford Bronco Rear cargo drawer system - JcrOffroad IMG_4272
Ford Bronco Rear cargo drawer system - JcrOffroad IMG_4275
Ford Bronco Rear cargo drawer system - JcrOffroad IMG_4279
Ford Bronco Rear cargo drawer system - JcrOffroad IMG_4409
Ford Bronco Rear cargo drawer system - JcrOffroad IMG_4416
Status
