Rear Axle leaking part 2
ColoradoKid26
Naughty Scotty
2021 Bronco Badsquatch, 2022 F-150 Tremor
As a continuation from this thread
https://www.bronco6g.com/forum/thre...tube-1200-miles-warranty-covered.73931/page-6
The dealer replaced an 'O' ring on a sensor that was leaking, and said the fluid levels were acceptable.
Fast forward a few months and 500+ miles, and my rear axle appears to be leaking from all 4 plugs welds.
I am wondering how much longer it will go before something catastrophic happens, and is it even safe to drive?
Is this fixable at the dealer level, or is that a whole R & R of the rear end?
Upper Left of Rear Axle
Ford Bronco Rear Axle leaking part 2 8-23 Upper left Axl
Upper Right of rear Axle
Ford Bronco Rear Axle leaking part 2 8-23 Upper right Axle
Lower Left of Axle
Ford Bronco Rear Axle leaking part 2 8-23 Lower Left Axl
Lower Right of Axle
Ford Bronco Rear Axle leaking part 2 8-23 Lower Right Axle
I had some fall trips planned with the Bronco, but I'll put them on hold now.
mcinfantry
Lee
Louisiana
Badlands 2 door
IF I WERE YOU ID MARK THE AXLE WITH A SCRIBE. THAT LEAK DOESNT SCARE ME FROM DRIVING…. IF THE AXLE ROTATES ID BE CONCERNED
ColoradoKid26
ColoradoKid26
Naughty Scotty
Have you used TTA?
I've used the TTA maybe 2x. I was on flat ground in a dirt lot doing a function check.
Honestly its something I have no use for.
