RCI engine skid installed with plastic bumper
anomdeplume
Tampa, Florida
2023 Bronco Base, 2023 Bronco Sport Badlands
Original plastic “splash guard.”
Ford Bronco RCI engine skid installed with plastic bumper IMG_4305
What that splash guard was ”protecting”
Ford Bronco RCI engine skid installed with plastic bumper IMG_4308
Coverage comparison part 1
Ford Bronco RCI engine skid installed with plastic bumper IMG_4310
Coverage comparison part 2
Ford Bronco RCI engine skid installed with plastic bumper IMG_4311
Combined comparison, flipped over
Ford Bronco RCI engine skid installed with plastic bumper IMG_4312
Ronin oil drain plug access is very tight. About 4” of clearance. I was able to reach in there and turn the Ronin cap, but might have to drop the skid plate for an oil change. I’ll know in a few months.
Ford Bronco RCI engine skid installed with plastic bumper IMG_4319
Finished look. Factory recovery points maintained with no modifications needed.
Ford Bronco RCI engine skid installed with plastic bumper IMG_4321
Install notes:
  • RCI instructions on their website reference lock nuts. But hardware provided included lock washers and regular nuts. Not a big deal but something to be careful about.
  • Provided bolts by RCI are grade 8 equivalent. OEM bolts are grade 5 equivalent but have larger diameter flat washers than the RCI washers. A keen eye will notice I reused my OEM bolts (splash guard bolts are same part as OEM bash/skid bolts). This is a can of worms, I know. I may rethink this later and switch them for the RCI provided bolts.
  • Some sharp aluminum burrs on the plate near bolt holes. Filed them before install. Wear gloves.
anomdeplume
anomdeplume
Tampa, Florida
@anomdeplume can you change the oil without dropping the skd plate?
I’ve changed the oil twice without removing the plate. But, it’s not easy. Very tight squeeze getting in there and I absolutely wouldn’t even think about it unless you have a Ronin type drain plug and you use an extension hose/tube connected to the drain screw. Without it you’re going to make a HUGE mess. Next time I plan to loosen the plate but not remove it.
bniknar
Bri
An old EcoDriver
Yes, I'm looking at Talon https://talonsgarage.com/products/ford-bronco-engine-skid-plate-2021-2024?variant=45201691017524 - I like the big gap for access to the oil drain plug.. However a little pricy for the aluminum.
