Rattling Windows
steni
Stan
United States
BMW 540
I've got to say when you spent 70k on a brand new vehicle you don't need your windows to play drums! I think the engineers at Ford need to go back and do some homework on this. The windows have to be either closed or open, nothing in between, this can be very annoying, also the more i look at the interior the more I feel I got robbed! Having said that, I love the design of my truck and that's what i fell in love with but a little more detail would have made it perfect!
Stan
MileHighCitizen
Al
Denver
Bronco 2D 2.7
Counterpoint:
Mine has front + rear locking diffs, sway bar disconnect, 33” a/t tires, 400 torqs, ~9” ground clearance and A/C, all covered by a 8 year extended warranty and cost $50k…I can live with a window rattle when the windows are halfway down while going over bumps in the road.
Maybe you bought the wrong vehicle for your needs?
steni
Stan
United States
BMW 540
Counterpoint:
2024 Wild track with sasquatch package, are you saying the more the vehicle cost the more noise it makes?
helifino16
Ron
Mount Sinai, NY (Long Island)
You'd be surprised at how easy that is to fix.
Get yourself a deep 10mm socket. Open the door and lie under it. There's two rubber patches (about 2"x3") (they're plugs actually) on the bottom of the door. They pull out easily.
Loosen the nut (maybe 1/2 turn) just inside that opening and push it to the outside of the door and retighten. Repeat for the other one and replace the plugs.
The hardest part of this process for me is getting up after I'm done. It made a WORLD of difference. I can ride with the windows cracked or 1/2 way down without the annoying rattle. It still MAY happen on a rough patch of road, but is significantly less than it was.
MileHighCitizen
Al
Denver
Bronco 2D 2.7
I forget to mention heated-seats, washout flooring, built in Nav, keyless entry, rain-proof interior when cruising with the removable top and rock rails.
I'm saying if you want all that and windows that don't rattle occasionally you're S.O.L.
You could always trade yours in for a Rav4 though. I hear their windows are quiet at all levels. And you won't have to complain on internet forums about being "robbed."
steni
Stan
United States
BMW 540
Wow!!! Sounds like you the owner of Ford Company! if you read what I wrote I said I love my truck. Just being honest on my part, my opinion that's it, was no insult to you or anyone with Broncos!
MileHighCitizen
Al
Denver
Bronco 2D 2.7
If I owned Ford I would've designed a Bronco with windows that don't rattle; it's pretty annoying.
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Gonna have to try this. Thank you!
akturbo
Seattle Eastside
It works. I found this fix after my closed driver window kept popping out of the seal on the freeway with high winds. It was pretty bad, I couldn't keep the window closed no matter what I did until the wind died down.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Stan
Hi Stan! I can look into your Bronco's window concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
Graham1911
Tommy
Prosper, TX
2022 Ford Bronco
Idid the same thing and it worked.
SoDak1623
Cole
South Dakota
1996 F150, 2022 Badlands MT
I thought that was just a consequence of the frameless windows. I've had that happen before on a trip when there was a very heavy cross wind to the south while driving west. I'll give this a try.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I think he's saying that he prefers Ford use the $70,000 on off road prowess instead of comfort features...BTW, All Wildtrak come standard with Sasquatch! lol
helifino16
Ron
Ah - that is a US only assumption. People in Europe and Asia have pointed out that their Wildtrac models are not Sasquatched-up.
Take any expensive car and it will compare unfavorably to something way cheaper for several features. If you prefer those features, then you probably should not have chosen a Bronco.
