Raptor Wheels - help needed
cmtaz
AZ
2023 Bronco
My 24 HPR came with wheels that do not have the trim rings:
Ford Bronco Raptor Wheels - help needed IMG_20251003_152447078_HDR
I have been contemplating an upgrade. Almost all of the wheels I like are Ford OEM:
Ford Bronco Raptor Wheels - help needed 1767723194245-1j
Ford Bronco Raptor Wheels - help needed 1767723252134-z
Ford Bronco Raptor Wheels - help needed 1767723314191-i0
Ford Bronco Raptor Wheels - help needed 1767723425885-b5
Which brings me to a question, Are all Raptor wheels the same as far as fit to the Bronco? I'd expect they'd all have a 6x135 bolt pattern, 17x8.5 size, it the backspacing I'm curious about.
Thanks
vrtical
Doug AI
GSMNP, TN
Fords
Well most seem to go to a 17x9 0 offset which is what I have but that profile will stick the tire out 1.5", but if you want to keep the same profile 17x8.5 the OEMs are decent but heavy. you can also run F150 raptor wheels. I have a set of Weld Racing wheels that are actually drilled for both bolt patterns and just use hub centric rings that are aluminum.
swamp2
You probably already know but the trim rings are non functional bead lock things which can be easily upgraded/replaced with real bead lock rings if desired.
Factory Braptor wheel is 17x8.5, +34 mm offset, 6x135, 87.1 mm hub bore. Ford F-150 Raptor R wheels are identical.
F-150 Raptor wheels with factory 37" tires are identical EXCEPT they are +30 mm offset.
Thus all of these wheels are interchangeable.
Spooled
Republic of Texas
Raptor, Model 3
I’ve seen a few pics of Raptor R wheels on a BRaaptor. They look the best out of all the OEM wheels IMO
Ford Bronco Raptor Wheels - help needed IMG_9506
HeliPilot
Kenny
CT
2022 2.7L SAS
Yes, Raptor wheels are the same bolt pattern and offset as Braptor.
RK Racing
Robert
Hawthorne, Ca.
23 jeep gladiator
I really like the way those look, but for me they would be a nightmare to clean.
swamp2
They are fantastic wheels, indeed.
Ond of my buddies put Braptor take offs (just with factory beauty rings) on his F-150 Raptor and those fit and look great.
