Radio issue/glitch
DrBrad
Brad
Tampa, FL
2021 Outer Banks Bronco
I've read through other posts, but seem to have a slightly different issue.
Randomly my radio seems to glitch out. It doesn't matter what audio source is playing. And even today I realized it happened with the radio off and even with the Bronco fully powered off. It started off a couple days ago and would happen for a few seconds and then clear up on its own. Today though it was constant for about a 20 minute drive. About 5 minutes into the drive home it resolved itself. I plan to check all of the connections at the battery, but I suspect that the wires aren't an issue. I read about the reset today and will try that tomorrow when it happens again. I'll post a quick video to show the issue.
DrBrad
DrBrad
Brad
Tampa, FL
I don't think the original video attached.
jrollo7
James
NY
Range Rover Sport
I’ve had intermittent other issues like no sound, or off/on push button doesn’t work then it just resolves itself. I keep updates ON (maybe some updates cause some of the temporary issues) and I’ve done a reset once a few months ago. Mine is a 2023 BD.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Brad! I can look into your Bronco's audio concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
Karl_in_Chicago
Karl
Chicago
While you're under the hood check the fuses, too. Don't know that it would be involved but there were enough reports of poorly seated fuses from the factory that it doesn't hurt to check.
Bronc-E-Donk
Logan
North Texas
Did ford ever respond to you? My 2023 has similar issues, thought it was CarPlay but even FM radio does wonky stuff like this.
DrBrad
DrBrad
Brad
Tampa, FL
Yes, I messaged them and eventually took it in to the dealership. I had replaced all of the stock speakers, but I had to put the originals back in. When I put the new speakers in, I had added some bass blockers on the dash speakers. But when I took the new ones out, one of the bass blockers had overheated and a wire had become unsoldered.
So when I took it in to the dealership, the audio glitch was gone. I can't say that it was the bass blockers 100%, but it was the only thing that I could find that seemed wrong.
