Quiet Axleback suggestions
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
I wasn't sure what motor/trans OP has. I have a 4-dr (longer tailpipe vs 2-dr) 2.3L manual and am in the process of installing the Steeda. I added an tip extension (black) that has a slight bend and plan on turning it sideways (vs down). I have watched various videos on stock vs Steeda and it's still a bit tough to know if I will love it or hate it. Since my 2026 has ESE (all have since 2024), the only way to evaluate the sound coming from the exhaust is to drive in Eco which is suppose to disable ESE. Hopefully tomorrow, I will finish the install and can evaluate the added noise. I had hoped it would be similar to the ESE fake added noise and plan on disabling ESE either by myself or ask the dealer.
JL8jeff
Ewing, NJ
With that downpipe, you're going to get noise with pretty much anything other than the stock muffler. I think you would need to come up with a custom mix of muffler near the driveshaft and a resonator across the rear where the stock muffler was. I have the MBRP overland with my 2.7 and it's fine most of the time. When I took the top off for the first time, I was really surprised how loud it was without the top. And that's with the stock cats and y-pipe. So I'm sure it would be quite a bit louder with an aftermarket downpipe/cat. My guess would be the Borla touring or S-type I think that seemed to be the quietest. The MBRP stuff I have is both straight through so you probably need to find a real muffler/resonator that isn't straight through to have any hope. I would probably go back to the stock downpipe/converter and then most of the cat-back exhausts would most likely work fine (other than the obvious noise makers).
Sparky1337
Mustang GT
If you want to keep the downpipe, and a spicy muffler you should try a Vibrant resonator. It would still have volume but cut the drone down significantly if done right. You might still need to grab a different muffler if yours is a bottle type.
https://vibrantperformance.com/ultra-quiet-resonators-v1249/
Blakshukvw
Blue Springs, Mo
96 explorer, 99 explorer, 04 marauder, 23 bronco
I'm running the MRT Trail Rated Axle Back. Can barely hear it in the cabin but outside has a nice low tone. ZERO drone.
https://www.shopmrt.com/2021-Ford-Bronco-MRT-Trail-Rated-Axle-Back-p/90r232.htm
I concur. I too use the MRT Trail Rated GOAT muffler. I made my own axle back using this muffler and stainless 90 degree pipes from Amazon and it sounds great. Not loud at all when just cruising. Cold start it’s very noticeable but sounds great. Wide open throttle sounds even better. absolutley zero drone. I’m completely satisfied and would do it again.
I am currently building another axle back the same exact way but with a Borla Pro XS muffler this time. I just want to see how it sounds compared and I scored it new for $29.
Blue Hen
Delaware
18 Suzuki Vstrom 650XT, 22 Bronco Base MT SAS
What I like about MRT trail muffler. Smaller of course but the tailpipe turns down. Tucked up out of the way when off roading. Most exhaust has the tailpipe coming straight out the back. Either single or double. Louder yes, drone yes, not much louder than the tires. Still have stock tires, if people through mudders on what drone. So many choices and so many opinions of what sounds good or sounds like crap.
burgerking
america
none
Varex valved catback might be worth checking out. The price is about the same or less than the other 304 options.
jwhisl
James
Oklahoma
2025 Bronco
Roadbronc
Jerry
Northern ME
2005 Toyota Echo, 2014 Ford Mustang GT
I had this very same issue when adding long tube headers on my mustang. If you want anything near stock volume, I recommend you reinstall the stocker. It would be a shame to remove the downpipe, but just like headers on a V8, the exhaust noise is going to increase significantly. Your only quiet choice for aftermarket is likely Borla touring and they are super expensive and still may be louder than you want. It will still be a good amount louder even with stock muffler.
TacomaTex
Ryan
CO
Bronco V6
How bad is the drone? I'm between this and MBRP pro.
Mjasi3
Chicago
Blue Hen
Delaware
The tires which I still have the GY's. They both compete with the drone. I can hear the exhaust slightly more than the tires. Don't forget this is not my daily. I mostly drive it on weekends. I'm happy with my choice.
TacomaTex
Ryan
CO
Bronco V6
This isn't my daily either. I think that's the compromise. You either get an exhaust you can hear and deal with the consequences or get something quiet where you don't hear anything. The MRT sounds similar to the MBRP, but I can only really find one person with a legit MBRP review and good sound clips, so it makes the comparison difficult.
Only exhaust I ever regretted was a flowmaster on an old S10 blazer I had.
Blue Hen
Delaware
What I like doesn't mean you would like. I didn't want a muffler delete like North Shore's Rough Country. This was a compromise for me which I think sounds great. Good luck with your decision.
