Questions for Ford before VIN assignment
Fedexman1978
Kansas city
2023 Bronco Badlands
Mine is is regards to the FPP off road suspension system. Everything I can find leads to the fox 2.5 system that's on the Ranger. Is this a lift, a level, or both? And if a lift, how substantial, and will it be incremental over all trims?
RednWhite89
RednWhite89
Evan
DMV
1989 Bronco
I think the answer is yes you can access it, but it requires removing the slide out shelf so it is a PITA and you won’t be able to use it for secure quick use storage.
I am betting to install it you remove the four lasso tie downs and bolt the enclosure into the tie down bolt holes, then slide the “tailgate” in.
Sounds like we need some clarification 🤣
Felix808
SRV CA
If fender flares start disappearing then just drill a few holes and zip tie them. I don’t think the flares will be as in demand as you think.
At lest not the pocket or oversized flares 😁
RednWhite89
RednWhite89
Evan
DMV
1989 Bronco
Right?!? Haven't seen an aftermarket flare that begins to approach satisfactory.
AceGoliath
Charles
IL
21 Bronco OBX SAS , 22 Maverick XLT, 10 Fusion SE
Looking for a confirmation if the split front tire cam view is specific to just trims with Rock Crawl GOAT mode?
Rumored extra camera in sideview mirror in addition to the 360 deg. camera.
I haven't found it mentioned anywhere in any literature.
BN claims(I know not always correct) it's only available with Rock Crawl mode, but we have seen preproduction WildTraks with the feature.
Heffe66413
Jake
Indiana
Thought it would be worth gathering a comprehensive list of questions for Ford to answer while we can still make changes to our orders. I'll start with two of my own:
1) What is the difference between BL stock suspension and Sasquatch?
2) Are we getting the BYOD picatinny rail? Limited to any specific trim?
Edit:
3) Difference between regular and high level instrument panel?
4) Are there any theft prevention measures for fender flares? (Maybe similar to wheel locks)
5) Rollout timing for slide out "tailgate"? Does it compromise access to jack and under floor storage?
6) Has the brush guard been redesigned? Pictures/details?
I think Ford will be hesitant to reveal 2022 changes out of fear that many would delay their orders until 2022.
RednWhite89
RednWhite89
Evan
DMV
1989 Bronco
I get that, not trying to understand any MY22 changes, just final decision making for my hopefully 2021 model.
RednWhite89
RednWhite89
Evan
DMV
1989 Bronco
Added, thanks!
RednWhite89
RednWhite89
Evan
DMV
1989 Bronco
Would this make you reconsider a specific trim or whether to Squatch or not? Just curious
Fedexman1978
Kansas city
If it is a lift and makes it possible to run 37's out of the gate, I would forgo the Sasquatch and piecemeal my build. I'd hold off until the DIO options of the FPP off road suspension and the ability to gear with 4.88's were available in the 4th qtr.
abe
Abe
Indiana
16 F150 XLT 2.7 (sold 😥), 84 Chevy K5, 09 Chevy T
That's what I was thinking
Used2jeep
Massachuvian
2007 Crown Vic P71
Well it has to be able to have the High package so OBX, BL, WT, FE. WT does not have Rock GOAT and unsure about OBX.
Thinking about it more, it is probably activated by 4L.
Used2jeep
Massachuvian
2007 Crown Vic P71
