Question on transmission temp gauge
tock13
Tony
WA State
Mazda, 66 Honda CT90, ‘94 Toyota Xtra cab
I’m still getting used to the dash layout and had a question on the “gauges” screen.
I noticed the transmission temp gauge is sort of skewed to the right compared to the engine temp gauge and I don’t get why that is.
The pic shows both engine and trans at the same temp…but the transmission temp needle is way farther to the right heading red. I haven’t done any long trips in yet but it seems 185 where it seems to sit a lot so I would expect the gauge to be a lot more centered…it makes it look like it’s on the hot side.
Probably no big deal but sort of freaks me out having it so close to the red when it climbs to 190ish.
Ford Bronco Question on transmission temp gauge IMG_0474
Ducati1098
Normal operating temperature for both are different, so even though they’re the same temperature, the gauge reading will seem different.
That gauge display is very deceiving, switch to the individual ones to get a better idea of the temperature in relation to the cold/hot side range of each
tock13
tock13
Tony
WA State
Thanks for the tip! I’ll check out the other screens to see how the temps read.
I really appreciate all the knowledge you share with folks on the board!!
